johnemms
posted on 28/2/12 at 12:54 PM |
Camber Question
Can I set my camber by simply taking measurements?
Flat on the ground : all equal and squared up..
Measure bottom of inner wheel rim to rim.
Measure top of inner wheel rim to rim.
Now adjust the top measurement a mill or two smaler to give neg castor..
cheeers
jon
[Edited on 28/2/12 by johnemms]
phoenix70
posted on 28/2/12 at 01:05 PM |
is that not the camber you are talking about?
johnemms
posted on 28/2/12 at 01:09 PM |
Cheers.. just edited it... thats rushing a job!
DavidM
posted on 28/2/12 at 01:22 PM |
Yes you can. If it is level on level ground, check and adjust the camber against a vertical level. It's how I did mine.
Proportion is Everything
loggyboy
posted on 28/2/12 at 01:23 PM |
You really need to be measuring from vertical, not between tyres on each side.
Measuring/finding an accyurate vertical is tthe key, as above make sure you on level ground and use a spirit level.
[Edited on 28/2/12 by loggyboy]
adithorp
posted on 28/2/12 at 02:29 PM |
yes, you need to measure each wheel against vertical. If you just measure between the wheels you could have one slightly positive camber and one a lot
negative and it'd just measure as negative.
To eliminate any slope on the ground, measure each wheel then turn it around and measure on the same spot but facing the other way. Take an average of
the two sets of readings readings.
http://jpsc.org.uk/forum/
johnemms
posted on 28/2/12 at 03:26 PM |
Stupid question time again ...
When they say 1 degree - do you take a protractor from the hub and follow the line?
If so - centre is a dot - going outwards 1 degree at my rim is like 2mm?
so take 4mm out of the top measurement - presto 1 degree of camber ...
cheers
jon
loggyboy
posted on 28/2/12 at 03:30 PM |
1 degree is 1 degree, it doesnt matter where you measure it from:
johnemms
posted on 28/2/12 at 03:36 PM |
So just put a little neg into the wheel with a spirt - bubble thing then ,,
loggyboy
posted on 28/2/12 at 03:43 PM |
I assume you are getting ready for IVA and want to ensure you have some self centering, in which case, yes, just get a roungh amoungt of nominal neg
camber, then when you are roadworthy, get it down to a decent tyre place with laser allignment and get it all check out and set up.
Fred W B
posted on 28/2/12 at 07:14 PM |
Across 15" (381 mm) 1 deg is 6.65 mm
Across 13" (330 mm) 1 deg is 5.76 mm
If you want about 1 deg tape a 6 mm thickness spacer to your spirit level and adjust till it shows dead vertical, when held against the wheel with the
spacer against the upper part of the rim.
Fred W B
[Edited on 28/2/12 by Fred W B]
johnemms
posted on 28/2/12 at 07:39 PM |
1/4 inch left n right ...... coool .. sorted..
