Author: Subject: Rs 4 spokes on sierra uprights?
RAYLEE29
posted on 1/4/12 at 08:40 PM Reply With Quote
Hi, thought id try an Rs 4 spoke on the front of my car today as i have a spare set and like the retro look they would give.
now it seems they hit on the caliper slightly I tried spacing the wheel out by about 1/2" and just it about misses.
it looks like if i ground a bit off the caliper and holder it would work, has anyone tried this?
next has anyone fitted Rs 4 spokes over sierra rear disc brakes? im happy to alter the upright if i need to.
thanks in advance.
Ray
[Edited on 1/4/12 by RAYLEE29]
build diary1
http://picasaweb.google.com/raylee290/RoadsterPics#
build diary2
http://picasaweb.google.com/raylee290/KITCARPICS?authkey=Gv1sRgCI2AouyYgpuQmAE#
redscamp
posted on 1/4/12 at 11:00 PM Reply With Quote
what size discs do you have, 239.5mm non abs or 260mm with abs?
snapper
posted on 2/4/12 at 05:12 AM Reply With Quote
I had the Capri Lazer wheels and they needed a 1/2" spacer up front.
Some one on here had a batch of rear caliper springs made up that we're smaller and gave the required. Learance.
I eat to survive
I drink to forget
Norfolkluegojnr
posted on 2/4/12 at 08:19 AM Reply With Quote
When fitting Laser wheels to Dads Velocity we had to grind (gently) a bit of the casting off the caliper.
Apparently, its a common ish problem, because the casting moulds were a bit industrial.
U2U norfolkluego if you want and he'll confirm what he had to do.
RAYLEE29
posted on 2/4/12 at 09:20 AM Reply With Quote
Thanks for responses I havent measured the discs but it all came of a late estate with abs so probably the larger ones.
Ray
build diary1
build diary2
posted on 2/4/12 at 09:29 AM Reply With Quote
What about the effect to handling? It moves the tyre contact patch put from the line of the upright and buggers up the geometry???
RAYLEE29
posted on 2/4/12 at 10:00 AM Reply With Quote
So is it better to use the original sierra 14" wheels? car is sat on them now.
Ray
build diary1
build diary2
