Author: Subject: smoking diesel corsa
dave r
posted on 8/5/12 at 07:57 PM Reply With Quote
lo all the wifes 1.7 di corsa nearly failed its mot on emmisions last week.... got through with a tin of injector cleaner in it
now its been refueled, its smoking again
new air filter, and it does get opened up to blow the cobwebs out everytime i get in it.....
suggestions as to what to try to cure it ??
dave
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
monck
posted on 8/5/12 at 08:07 PM Reply With Quote
Not sure of the answer but ill keep watch on the thread as my 1.9 306 is horrific
Duncan Mould
posted on 8/5/12 at 08:23 PM Reply With Quote
Try taking the mechanical fuel injectors out and have them ultrasonically cleaned and callibrated. If you take them to a bosch agents should only cost about £50 ish.
You will probably find they are staying open/dripping if its black smoke.
Hope that helps
ASH3
posted on 8/5/12 at 09:28 PM Reply With Quote
Poss EGR requires clean out plus check Turbo
waste gate is not stuck open I've had that before.
