Author: Subject: Bolt standards for calipers.
emwmarine
posted on 13/5/12 at 02:45 PM Reply With Quote
It says in the IVA that 88 is the minimum spec.
I have seen 12.9 cap head m10 bolts for sale. Presumably these are stronger and ok??
Building a Dax Rush.
tomgregory2000
posted on 13/5/12 at 04:05 PM Reply With Quote
Yep, stronger indeed and make sure you apply some thread lock onto them when fitting the bolts
RAYLEE29
posted on 13/5/12 at 04:06 PM Reply With Quote
Hi,yes the higher the number the higher the tensile strength so 12.9 is good and probably what would be fitted oe maybe 10.2 but not as low as 8.8 even if the book says so I wouldn't use 8.8 on calipers.
Ray
build diary1
http://picasaweb.google.com/raylee290/RoadsterPics#
build diary2
http://picasaweb.google.com/raylee290/KITCARPICS?authkey=Gv1sRgCI2AouyYgpuQmAE#
RAYLEE29
posted on 13/5/12 at 04:08 PM Reply With Quote
Must learn to type faster lol
build diary1
build diary2
