Author: Subject: Hydraulic brake level switch sensitivity
bi22le
posted on 20/5/12 at 02:49 PM Reply With Quote
Hi all.
I mentioned this in another post but did not get much help so thought I would put up a new topic.
On my striker the brake lights use a hydraulic switch which is on the rear line. The press needed on the pedal to operate the lights is more than spirited driving so I have concerns with the people behind me.
I have bled the switch by undoing it, putting press of the pedal until it leaks then tightening back up. This has not changed anything.
Can I get a more sensitive switch or is it just a case of putting it on the front due to brake bias pressures?
Biz
Please read my ring story:
macc man
posted on 20/5/12 at 02:57 PM Reply With Quote
Sounds like a faulty switch. It should not take much pressure to operate. Mine is at the rear and works with little preesure.
jacko
posted on 20/5/12 at 03:23 PM Reply With Quote
I had the same problem and was told a VW brake switch was the best to use , I did not go down this route .
And I fitted a micro switch to the peddle / bulkhead it is the best way in my mind
Jacko
lewis
posted on 20/5/12 at 04:19 PM Reply With Quote
Would def be better in front of the system ( fwd of any brake bias)
I am a driving god!..........sort of
posted on 20/5/12 at 04:49 PM Reply With Quote
OEM VW brake switch.. Eurocarparts, PN 464550020 £5.45 Its made by FAE.
big_wasa
posted on 20/5/12 at 04:54 PM Reply With Quote
On the front brakes is best.
ryanill
posted on 20/5/12 at 07:06 PM Reply With Quote
I too use a micro switch on the pedal. As soon as the pedal moves the lights come on
posted on 20/5/12 at 07:21 PM Reply With Quote
Any pics? Is it a floor pedal? I fancy doing it myself.....
I predict a Riot
posted on 20/5/12 at 07:28 PM Reply With Quote
The problem isn't with your switch, it's your bias bar.
Under light brake loading the rear system isn't getting used.
Move the switch to the front system or preferably fit a switch to act directly off of the pedal.
mad-butcher
posted on 21/5/12 at 10:08 AM Reply With Quote
as said in various posts it needs to be mounted with the wiring pins at the bottom so any air will rise
bi22le
posted on 22/5/12 at 09:51 AM Reply With Quote
Personally i disagree with this.
I think that if the switch is at the highest point with terminals up then its easy to bleed and check that there is no air at the switch. Also saves adding an extra bleed valve. Also grantees that there is no air at the switch.
Would a faulty switch present as not sensitive? I would of thought that it just would not work. Also is the VW more sensitive than the average switch?
Biz
daviep
posted on 22/5/12 at 10:34 AM Reply With Quote
Biz
Sorry but I think you have the wrong end of the stick with regards how a brake system bleeds.
If you mount the the switch with terminals up it is impossible to remove air which is trapped inside the switch, by loosening the switch you are trying to bleed at the lowest point when all air is at the highest point.
If you mount the switch terminals down the the fuid will naturally flow down in to the swich and displace the air into the pipe where it will pushed in to a caliper / wheel cylinder and be bled out normally, there is no need for any extra bleed points. I always give the switch a light tap with a spanner just to make sure any small bubbles rise up into the pipe.
I'm using a VW master cylinder which has the switches screwed in to the MC as standard - termminals are downwards
Davie
bi22le
posted on 6/8/12 at 06:12 PM Reply With Quote
Either way I have fixed it now, new switch!!
I have updated this for reference. Future searching \ fountain of knowledge and all that jazz.
The brake light switch was faulty and replacing it with a new switch from Eurocar parts FAE 464550020.
Biz
