Author: Subject: Help me identify this diff please
82 Locost
posted on 25/5/12 at 08:00 PM Reply With Quote
I was told this is an English diff, but it doesn't look like my other diffs (the centre bit is enclosed and it's heavier).
HowardB
posted on 25/5/12 at 08:17 PM Reply With Quote
have you checked the ratio?
Howard
82 Locost
posted on 25/5/12 at 08:37 PM Reply With Quote
4.1 is written on it in tipp-ex, which would point to a standard English ratio, but I've never seen one with a bulky lump in the middle. I'm more used to something like this:
adithorp
posted on 25/5/12 at 08:55 PM Reply With Quote
LSD?
http://jpsc.org.uk/forum/
HowardB
posted on 25/5/12 at 09:08 PM Reply With Quote
Originally posted by adithorp
LSD?
I've never seen inside one that is LSD, so can't comment
Howard
snapper
posted on 26/5/12 at 05:32 AM Reply With Quote
The way to tell if it's an LSD is to put the half shafts on and turn one if they both move the same way it's an lsd
I eat to survive
I drink to forget
minitici
posted on 26/5/12 at 07:50 AM Reply With Quote
That is definitely an LSD.
You can see the plates and the split line at the cross-pins in the first photo.
82 Locost
posted on 26/5/12 at 08:53 AM Reply With Quote
Thanks guys, I'll do the driveshaft check.
posted on 26/5/12 at 10:18 AM Reply With Quote
I wouldn't bother, it's 100% definitely an LSD.
[Edited on 26/5/12 by MikeRJ]
82 Locost
posted on 26/5/12 at 03:08 PM Reply With Quote
That's amazing. I didn't even know I had it.
[Edited on 26/5/12 by 82 Locost]
82 Locost
posted on 26/5/12 at 04:19 PM Reply With Quote
Right. I've just been for another look and it's definately an LSD. However, it's not an English Diff as it's larger but it is a 4.11. It also takes 25 spline half shaft (not 22 spline English). The flange has 8 holes, which appears to allow a small or large prop-shaft flange to fit.
The numbers:
Crown wheel 72VB 4210-aa 9-37
Casing 81VB 4025-AB (I think, it's quite corroded)
Any ideas?
82 Locost
posted on 26/5/12 at 07:55 PM Reply With Quote
Apparently it's a Transit diff.
