Author: Subject: Megajolt Pinto Map
TrophyJem
posted on 1/6/12 at 03:46 PM Reply With Quote
Megajolt Pinto Map
I've just got my Megajolt installed and now need to put a map on it as a starting point.
Has anybody got a map they are happy with for the Pinto that they would care to share?
The engine is;
2.1L Pinto
FR32 cam
Large valve head
Twin 40 Dellortos with TPS
se7ensport
posted on 1/6/12 at 04:27 PM Reply With Quote
I used the following with great success on my old Pinto, it had a large valve heavily skimmed head with FR33 cam and bike carbs initially and then GSXR throttle bodies. I don't have an exportable format that will work with megajolt, but you can transpose the figures easy enough, usual comment applies about shared maps etc: no two engines are the same, my trigger signal could be in a different place than yours, listen out for pinking, use with caution etc...
Pinto map
Pinto map
Pinto map 3D
Pinto map 3D
shaft
posted on 1/6/12 at 05:55 PM Reply With Quote
I have a map i can email to you.
It was tweaked on the rolling road.
Spec:
2.0l Pinto, Blade carbs, FR32, Big valve head.
U2U me your email and i'll send it over for you.
my opinion might be wrong you know...
My Zero Build Pics
TrophyJem
posted on 1/6/12 at 06:11 PM Reply With Quote
Pinto map
Pinto map
Pinto map 3D
Pinto map 3D
Thanks for that. I guess I might need to tone it down a bit from your settings.
shaft
posted on 1/6/12 at 06:19 PM Reply With Quote
Map sent via email.
My Zero Build Pics
ryanill
posted on 5/6/12 at 08:05 AM Reply With Quote
Hi all
Sorry to hijack this thread but any of you guys got a base map for a standard pinto on bike carbs ?
Iv recently put a mega jolt in my Indy. Now need a map to
Any help would be great
Ryan
mcerd1
posted on 5/6/12 at 09:16 AM Reply With Quote
^^ any twin carb map should be a good enough starting point
here's a few I've collected:
Pinto Maps Linky
ryanill
posted on 5/6/12 at 09:21 AM Reply With Quote
Cheers for the link
Got something to do on the bank holiday now
Ryan
ryanill
posted on 5/6/12 at 09:33 AM Reply With Quote
Pinto Maps Linky
just noticed that the load values go over 100%
is the because they are for a engine with a MAP rather than a TPS ?
ryan
mcerd1
posted on 5/6/12 at 09:58 AM Reply With Quote
some of them might be for a MAP version, they are ones I picked up from a few different sources
you can easy change the setting to TPS and adust them from there
