Author: Subject: CNC drawing for paddle shift wanted can pay/ donate!
ChrisRidge
posted on 12/7/12 at 11:44 AM Reply With Quote
Hello,
As title i'm after a cad drawing of a paddle shift & bracket. No problem paying for it. Sure someone has one! Its for my car & not for re-sale.
Chris
vanepico
posted on 12/7/12 at 07:56 PM Reply With Quote
Ok what size do you want?
ChrisRidge
posted on 12/7/12 at 08:19 PM Reply With Quote
Middle size!?
Steering wheel is 12" Are you designing from scratch?
Chris
vanepico
posted on 12/7/12 at 08:33 PM Reply With Quote
You mean something like this?
Is this something to send off to a fabricator?
I need to know what kind of linkage to the gearbox do you have, is there anything that the pivot can mount to?
Some pics of the area would help
I just started a CAD job a few days ago so I need some practice!
JekRankin
posted on 12/7/12 at 08:39 PM Reply With Quote
Here's mine, with some basic dimension attached to give you an idea of its size. It pivots on a pair of M5 rod ends, which are bolted to a machined sleeve on the end of the Sierra column.
I could easily change the dimensions on the paddle to suit the size you would want and send you a DXF which you could get Andyw7de on here to water jet cut for you.
Paddles
Paddles
Paddles 2
Paddles 2
vanepico
posted on 12/7/12 at 08:49 PM Reply With Quote
there you go one already made I was wondering though, if it is cable operated, how many turns can the steering wheel still do?
Mad Dave
posted on 13/7/12 at 06:12 AM Reply With Quote
The paddle shift is fastened to the steering column
renetom
posted on 13/7/12 at 08:10 AM Reply With Quote
paddle shift
Hi
We used much the same as above with rod operation.
Works fine & positive shift.
See our picts archive.
good luck
René
ChrisRidge
posted on 13/7/12 at 01:49 PM Reply With Quote
Paddles
Paddles
Paddles 2
Paddles 2
Already drawn up! Did you have this machined yourself? Where did you source the mount for cable?
Thanks, Chris
ChrisRidge
posted on 13/7/12 at 01:50 PM Reply With Quote
Sorry scrub that, just read it again!
More than happy to pay for the file.
Thanks, Chris
vanepico
posted on 13/7/12 at 08:20 PM Reply With Quote
Which would mean the cable coils around the steering column?
Mad Dave
posted on 13/7/12 at 08:25 PM Reply With Quote
Take a look at the drawing; the rod ends fasten to the steering column outer sleeve so the paddle shift, cable or mechanical linkage are stationary
vanepico
posted on 13/7/12 at 08:27 PM Reply With Quote
Oh right, I was not aware steering columns had outer sleeves
