Author: Subject: Audi A3 Oil pressure problem???
kickinthenuts
posted on 13/7/12 at 03:27 PM Reply With Quote
Hi guys,
I have got an audi A3 1.8T with the oil warning light on. Got a lot of top end noise so I'm guessing oil pump has gone and obviously don't want to damage the turbo or big end through oil starvation. Just wondering if anyone has ever done one and how hard it is to do. Do i need to lock of any pulleys or anything like that. As always, any help would be appreciated.
posted on 13/7/12 at 04:00 PM Reply With Quote
My guess would be either the oil pressure relief valve stuck oil pump drive knackered, big end failure or a problem with the oil pump suction pipe and strainer.
kickinthenuts
posted on 13/7/12 at 06:07 PM Reply With Quote
Thanks for the reply. i'll need to get the bottom end opened up and see what the problem is. Don't think its the PRV as the light came on and there was no noise from the top end and now there is. think the pump has had it.
posted on 13/7/12 at 06:14 PM Reply With Quote
Some of the Audi engines have the oil pump driven by a chain and sprockets which wear badly and slip causing lack of oil pressure . New chains and sprockets are no longer available because the pump has been modified to be driven by gears . IIRC the cost is in the region of £800?
Mad Dave
posted on 13/7/12 at 06:17 PM Reply With Quote
I had an A6 with a 1.8T engine it destroyed itself due to a blocked oil pipe. It's a metal pipe with a 90 degree welded mitre joint and it blocks because it's not a continuous bent pipe. Apparently it's a common problem in these engines
[Edited on 13/7/12 by Mad Dave]
CRAIGR
Contributor
Posts 2750
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 13/7/12 at 06:34 PM Reply With Quote
The older golf gti's used to suffer from blocked oil strainers so wouldn't be surprised if these do to. Whip off the sump clean strainer and bobs your uncle all good again.
[Edited on 13/7/12 by CRAIGR]
GOJO
posted on 13/7/12 at 06:39 PM Reply With Quote
90% sure it will be the oil strainer pipe, usual fix is a pump and strainer and the o ring that join the two!, if it has been stopped quickly it should be ok 1st thing to seize is the turbo check the nut on the impellor is still there and that it spins feely and take the rocker cover off and check the shells in the bearing caps when the sumps off check a couple of main bearings, it shud b ok if the turbo is ok and the top end it should be fine, the turbo feed line can carbon up on those also worth cleaning though or replacing
deltron63
posted on 13/7/12 at 06:53 PM Reply With Quote
Blocked oil pick up and strainer. Mine did the same the other week, sump off clean everything it might be OK. Iv'e had no problems since
brookie
posted on 14/7/12 at 04:00 PM Reply With Quote
my sister had this problem and it ended up being the above shad had a a4 1.8t engine so the same engine it not a small job as well
