New Topic New Reply
Author: Subject: Progress + pictures
Bizarro
posted on 7/9/12 at 05:38 PM Reply With Quote
Progress + pictures
Had last week off work and managed to make some good progress on my Indy.
Still a few things to do like trim, mirrors, front/side indicators, aero screen, cat, bonnet catches etc... but generally pleased with my progress.
Im pre IVA so any comments, critisism or praise appreciated
MK3
MK3
MK6
MK6
MK5
MK5
MK7
MK7
MK8
MK8
MK9
MK9
Unsure what to do air filter wise?
MK1
MK1
MK10
MK10
gavin174
posted on 7/9/12 at 05:55 PM Reply With Quote
real nice build there...
just a couple of things..
do the front arches come down far enough at the back of the wheel,
relays under dash on passenger side will need covering
not sure on radius edge on speedo/rev counter
will toggle switch on tunnel be ok
some people have failed IVA with grooved gear knobs I believe
really does look good thou
[Edited on 7/9/12 by gavin174]
Bizarro
posted on 7/9/12 at 06:10 PM Reply With Quote
Thanks..
I positioned the front arches so they are level with the front of the tyre, looking at IVA manual I believe the rear of the arch should be 50 degrees or max 150mm from the centre of the wheel. If Im reading this right they should be OK, but if Im not then please let me know.
I do think they look better further back but wanted to be sure about covering the tyre.
I wasnt sure about the toggle switch, its for the indicators as I wanted to get away from the Ford column switch. Spose I could use mimi type guard around it to be sure?
Davegtst
posted on 7/9/12 at 07:02 PM Reply With Quote
Put big O rings in the grooves of the gear knob then it should be fine. I have a toggle switch on the tunnel aswell for the indicators. All i did was put switch guards either side so the sphere couldn't touch it.
fullpint
posted on 7/9/12 at 07:08 PM Reply With Quote
10 out of 10 for that dash.. Looks very nice. Best I have seen..
I've over 28 years in dealing with magnesium wheels. Refurbishment and can powder coat most metal parts. Visit my web site if you wish..
www.tpcs-magnesium-refurbs.co.uk
maccmike
posted on 7/9/12 at 10:37 PM Reply With Quote
great detail mate
avagolen
posted on 8/9/12 at 08:37 PM Reply With Quote
Looks great.
I am not sure about the handbrake lever if it is being left uncovered.
With reference to the switch guards for indicator switch on tunnel.
I do not know how much the mini ones cost, but I have purchased stainless ones from the
US for $6.99 each. Excellent service.
www.periheliondesign.com.
Just make sure you select the 5mm diameter ones for IVA....
HTH
Len.
Davegtst
posted on 8/9/12 at 09:25 PM Reply With Quote
Mine are from perihelion too. I bought a few from CBS then found that the perihelion design ones are exactly the same and a load cheaper.
blowden86
posted on 9/9/12 at 07:41 PM Reply With Quote
Davegtst that is one stunning dash!! What edging have you used around your clocks and gear indicator? I can't even see the join!
Ben
My MK Indy R GSXR 1000 Build Diary: http://www.suma-uk.com/indy/
Davegtst
posted on 9/9/12 at 07:47 PM Reply With Quote
Why thank you kind sir. It's u trim from cbs, I tried other u trim from ebay but it didn't bend round the corners aswell. If you look closely the join is at the very bottom center.
FuryRebuild
posted on 9/9/12 at 09:03 PM Reply With Quote
Davegtst: seriously lovely piece of work. I just wonder how many hours? I'm not even remotely saying they're wasted, more saying craftmanship has its price.
What's your background? Did you have extra skills to bring to this great piece of work?
www.furyrebuild.co.uk
Davegtst
posted on 9/9/12 at 09:22 PM Reply With Quote
Thanks again although I can't see what the fuss is about. To be honest I don't think the dash took that long to make. The carbon dash is from mk alli did was cut holes in it and bolt and glue things on.
FuryRebuild
posted on 10/9/12 at 09:33 AM Reply With Quote
I feel a monty python sketch coming on.
When I got my fury all they had were the really simple slab sided dash boards.
I don't know if they've improved on them at all.
M
Spud1985
posted on 11/9/12 at 07:52 PM Reply With Quote
What gear shift indicator are you using and how did you fix it in its position?
Davegtst
posted on 11/9/12 at 08:03 PM Reply With Quote
It's a healtech gipro. It's only held in place by the U trim being a very tight fit.
Sorry bizarro looks like your thread has been a bit hijacked.
Bizarro
posted on 12/9/12 at 02:23 AM Reply With Quote
Yeah, I think it needs to be retitled 'davegtst's dash' !!
RK
posted on 15/9/12 at 01:50 PM Reply With Quote
One of the best dashes you'll ever see. Beautiful design, and that includes the tunnel cover.
mad-butcher
posted on 16/9/12 at 08:37 AM Reply With Quote
I would be seriously concerned about driving with front arches like that, spray off the roads and flicking stones at me, but I haven't read the the new IVA regs to be honest
tony
New Topic New Reply
