Author: Subject: Design finished
designer
posted on 8/10/12 at 07:26 AM Reply With Quote
Design finished
This is it, done.
Have changed a few things, now to get some steel ordered.
3view1
3view1
Daddylonglegs
posted on 8/10/12 at 09:04 AM Reply With Quote
Hmmm, will watch with interest
wylliezx9r
posted on 8/10/12 at 09:10 AM Reply With Quote
Design finished ? Best you connect those front push rods to something then
George Best
v8kid
posted on 8/10/12 at 01:07 PM Reply With Quote
I think he has it's a monoshock
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
wylliezx9r
posted on 8/10/12 at 01:19 PM Reply With Quote
Cheers!
I'm on about the other end
George Best
designer
posted on 8/10/12 at 01:28 PM Reply With Quote
The pushrods connect with a 'rose' joint the the end of the suspension arm.
v8kid
posted on 8/10/12 at 02:38 PM Reply With Quote
Cheers!
Oops! I missed that
Cheers!
Dualist
posted on 8/10/12 at 05:51 PM Reply With Quote
Yep, front suspension is still gonna fail as it is.
Rotary build coming soon...
Originally posted by RichardK
I recently discovered that pigs can p i s s sideways when being transported
designer
posted on 8/10/12 at 06:01 PM Reply With Quote
Tell me why?
steve m
posted on 8/10/12 at 06:06 PM Reply With Quote
No castor, or camber?
just my guess
Dualist
posted on 8/10/12 at 06:15 PM Reply With Quote
Tell me why?
As it was said in your other thread, the frame that the push rods and the shock are attached to will flex/twist.
designer
posted on 8/10/12 at 09:07 PM Reply With Quote
It's designed to flex and twist, as it acts like an anti-roll bar.
Dualist
posted on 8/10/12 at 09:27 PM Reply With Quote
Oh ok, I see it's gusseted, what is the material and grade.?
Have you run any Ansys or Cosmos sims on it, if so what are the results.? An anti roll bar will be high tensile but will flex, a welded structure will be stressed and prone to cracking if mig/tig welded unless stress relieved, are you gonna braze it.?
Sorry if I seem an a-hole, just in my experience it doesn't look like it's gonna work. More than happy for anyone to prove me wrong.
[Edited on 8/10/12 by Dualist]
v8kid
posted on 9/10/12 at 07:12 AM Reply With Quote
Really?
I never thought so. Surely any material will do as long as it is not deformed past its elastic or fatigue limit.
Cheers!
designer
posted on 9/10/12 at 08:57 AM Reply With Quote
Yes, that's right, anti roll bars can be made of 'normal' mild steel. It is when you start shrinking them to a piece 75mm long, like the racing guys, that you have to start using 'exotic' materials and heat treatments.
Don't get too influenced by what you read in technical articles, mild steel will be strong enough, and it will work.
The object of the design is 'simplicity'.
designer
posted on 18/10/12 at 09:53 AM Reply With Quote
3view without internals.
general arrangement
general arrangement
ray.h.
posted on 25/5/13 at 09:07 PM Reply With Quote
exactly what I was thinking of building. I half built a locost about seven years ago but personal circumstances decread it needed to be sold. such is life. I saw the reverse trike by malcom in trike mag recently and this has inspired me to delve back in to selfbuilding again.
my problems are what light weight uprights to use and what rack to use. I intend it to be very light weight, single seat, rear engine rear wheel drive.
I have been considering fiat cinquecento....has any one got any experience of this set up?
designer
posted on 25/5/13 at 10:12 PM Reply With Quote
Front uprights will be custom made, but very simple.
A large diameter, thick walled 'cup' with the spindle bolted through the end cap, the other end is left open. Thick walled tubes, top and bottom, provide the mounts for the ball joints.
front upright
front upright
ray.h.
posted on 27/5/13 at 01:30 PM Reply With Quote
thanks designer just trying to simplify the design and build process a bit by using off the shelf parts.im looking at all sorts of options, buggy uprights and brakes, centre mount racks etc. just seems theres so many options and huge variations in prices.
the reverse trike I saw was using morris minor uprights. very easy and cheap to obtain and very light weight when used on double wishbone set up. the guy had reduced the height by about 150 by the looks of it and inserted a spherical bearing on the top. it looks a well engineered solution.
