Author: Subject: Shock eye to small ??
Hopley89
posted on 30/12/12 at 12:46 PM Reply With Quote
Iv just got some shocks and the eye on the top and bottom are a lot smaller than the surspention brackets that I'm going to fit to the chassis would it fail the Iva if I cut up the bracket re weld it an put it on
I can't upload photos as I don't no how to
If you want to see photos I can email to anyone
Dan
mookaloid
posted on 30/12/12 at 01:10 PM Reply With Quote
most people just pack the gap with washers.
you can upload photos to your archive by clicking on 'photo archive' above then using the 'choose file' and 'upload' buttons.
grassracer
Are the shocks rose jointed or rubber bushes
If they are rose jointed you will need to fit sidespacers to allow the rosejoint to function, this will take up a bit of space either side, you might need a washer or two to complete the job.
Be aware also that most rosejointed shocks take a 1/2in unf bolt rather than a 12mm one, you may need to open the holes out slightly in your chassis/wishbone mounts
mark chandler
posted on 30/12/12 at 01:23 PM Reply With Quote
Get the correct thing from here
http://www.mcgillmotorsports.co.uk/index.php?act=viewCat&catId=30
Hopley89
posted on 30/12/12 at 02:05 PM Reply With Quote
Yea thay are rose joints ones there is a massive gap tho .. Ill upload photo now to show you
I didn't want to finish an take it to Iva an bloke says what's with 10 washers over side for ??
Dan
mookaloid
posted on 30/12/12 at 02:08 PM Reply With Quote
Washers in that situation are perfectly acceptable for IVA I would think
Hopley89
posted on 30/12/12 at 02:10 PM Reply With Quote
There is a 10mm gap iver side
Ill try with washers now and see how it looks an feel
Hopley89
posted on 30/12/12 at 04:43 PM Reply With Quote
Iv tried it
It looks ok also looks crap I'm sure there is a better way of doing it . Cut the brackets down abit reweld so I can put a couple of washers in it instead of 20
Dan
AdrianH
posted on 30/12/12 at 06:10 PM Reply With Quote
Could you not cut down/turn off some crush tubes?
Adrian
Why do I have to make the tools to finish the job? More time then money.
