Author: Subject: Zetec with 16 bent valves - FREE TO COLLECT
nre
posted on 24/1/13 at 02:07 PM Reply With Quote
My 1800 zetec suffered a cam tensioner failure last year, the engine is now sat around gathering dust. Head is off, all 16 valves are bent, pistons have slight marks from valve contact.
Bottom end should be ok - was running well prior to the 'incident'!
It's a 1994 engine, 130ps spec.
If anyone wants head, block or both, drop me a message.
Collect from Warwick...
Sylva Mojo Zetec on GSXR750 throttle bodies...
www.mymojo.co.uk - Facebook feed
JPSC Forum - A dedicated forum for discussion on all things relating to Jeremy Phillips designed cars
Including the Star, Leader, Striker, Phoenix, Fury, Jester, Stylus, Mojo, Riot, J15 & Vectis
cliftyhanger
posted on 24/1/13 at 06:06 PM Reply With Quote
don't suppose you have the top and lower cambelt covers do you? I am still looking (only got the middle one )
nre
posted on 24/1/13 at 06:12 PM Reply With Quote
One of the bits of the cambelt cover has a hole through it courtesy of the exploding cambelt tensioner pulley, think it is the middle one, so should have top and bottom ones available... I'll go have a dig through the parts bin!
cliftyhanger
posted on 25/1/13 at 07:18 PM Reply With Quote
This may be a bit of luck for me!! At last
dave-69isit
posted on 25/1/13 at 11:27 PM Reply With Quote
engine
hello is the engine stillavailable please can collect any time
nre
posted on 26/1/13 at 08:53 AM Reply With Quote
Bottom half of engine just been picked up by madteg.
Still have the head.
cliftyhanger - if you u2u your email address I'll send you a pic of the bits I found - hopefully they are what you are after!
