Author: Subject: Ford Zetec/Duratec AMP Loom connector (old or new)
mikey p
posted on 28/3/13 at 04:41 PM Reply With Quote
I'm after one of these housings on the loom side.
http://uk.mouser.com/ProductDetail/TE-Connectivity-AMP/184000-1/?qs=sGAEpiMZZMs7eK6h2EBtKibIuD3x11VKzkSsz1e6ajQ%3d
For one of these Type 1a sensors -
http://www.webcon.co.uk/Downloads/K40016%20Ford%20Zetec%20(Black%20Top)%20Eng%20Temp%20Sensor.pdf
Has a central Keyway.
I only need the housing, I have new pins seals etc.
Ideal if you have an engine from a scrap yard which has had the loom cut off.
Mike
big_wasa
posted on 1/4/13 at 06:38 PM Reply With Quote
Type 1a 1b should be the same.
I am sure I have one, its just the ecu coolant sensor plug.
If you want it just send me a Self addressed jiffy bag.
