Daf
posted on 14/4/13 at 08:08 PM |
Blanking throttle body holes
I'm currently in the process of spacing out some GSXR throttle bodies and I need to blank off the secondary butterfly and injector holes. I know
that a lot of people use chemical metal but I've seen some pictures where this has failed and I don't like the idea of a lump breaking off
and falling into the engine!
Looking round my garage earlier I noticed my hot glue gun - good for 193°C - might be a daft idea but I could make a nice bung with hot glue to fill
the hole. If it overflowed a little to create a mushroom on the outside it couldn't fall in.
Any thoughts? Is this a daft idea?!
mccsp
posted on 14/4/13 at 08:19 PM |
Personnally I think it won't last long. I had some aluminium plugs machined up had a step in diameter, with the bigger diameter so it
couldn't fall in), then cooled them in the freezer and inserted with threadlock. Then just filed the protruding bits off. Looks really good, but
I was able to get the machining done at work, not sure that would be an option anymore.
Why do it the easy way, when I can do things my way!
big-vee-twin
posted on 14/4/13 at 08:49 PM |
I used some roofing bolts with a large mushroom head glued in with epoxy same as a blank-pic in my archive secondary holes with liquid metal OK if
done correctly
http://www.triangleltd.com
Daf
posted on 14/4/13 at 09:01 PM |
I think I'll get some spacers turned down to fill the holes, I just wanted to finish them and get them on so I could look at it!
Furyous
posted on 14/4/13 at 11:07 PM |
Try some of these.
CORE PLUGS / FREEZE PLUGS 5 X 20MM CUP TYPE | eBay
They won't look as good as a turned down piece of aluminium, but they're cheap and easy. Check the size first, the ones I linked might not
be right. You should be able to get some that are a nice squeeze in the hole, then secure them in with a bit of epoxy or silicone sealant.
[Edited on 15/4/13 by Furyous]
