Author: Subject: GI Pro gear indicator wiring help needed
daveb83
posted on 23/4/13 at 11:38 AM Reply With Quote
I posted this into the BEC section the other day and no one has reply. Im posting here now incase someone sees this that didnt see the post in the BEC section.
Hopefully someone out there will have been in the same boat as me before now, im currently running a 96 honda fireblade 919 engine with an 893 ecu and have a Koso RX1N clock which has the speed sensor pick up mounted onto the driver side drive shaft (ie after the diff).
Am i right in thinking that if i run the gear indicator black/green wire into the ignition pulse generator wiring (yellow) and the speed sensor wiring into the Koso's speed sensor it will work ok and be able to calculate which gear im in, or do i need a have a second speed sensor somewhere different like on the prop shaft straight off the engine before the diff for the gear indicator to work properly
Thanks in advance
Dave
daveb83
posted on 28/4/13 at 10:57 AM Reply With Quote
BTT... does not body know or have any ideas
help please...
thanks
Dave
