Author: Subject: Acewell and IVA
40inches
posted on 29/4/13 at 01:23 PM Reply With Quote
Acewell and IVA
Anyone been through IVA with this? Did it pass, or did the Mode button have to be covered?
Wheel fitted
Wheel fitted
wylliezx9r
posted on 29/4/13 at 03:19 PM Reply With Quote
Isn't it located within the exempt zone of the steering wheel anyway ?
George Best
Dangle_kt
posted on 29/4/13 at 03:35 PM Reply With Quote
its not the radius that is the issue - its if the speedo can be changed to KPH, or turned off I think...
I dont know the answer, just clearing up the question.
Looks good by the way.
gavin174
posted on 29/4/13 at 03:44 PM Reply With Quote
I made up a little plate that i could rivet/stick over the buttons at the test centre if required...
it was never mentioned.
IVA 3 years ago
gdp66
posted on 29/4/13 at 04:52 PM Reply With Quote
I had a plate I was going to 'glue' over the buttons.
I switched through the modes, but he didn't notice it stopped showing the speedo.
take a plate/cover and hope he doesn't ask or press them.
I think the later acewells switch back to a speedo once you start moving.
40inches
posted on 29/4/13 at 05:08 PM Reply With Quote
Thanks chaps. I think I,ll make a cover plate for my "just in case" supply.
Andybarbet
posted on 29/4/13 at 05:25 PM Reply With Quote
I have the same digidash but was curious as to what extra gauges you have fitted ?
I was thinking of doing the same & using the digidash mainly for the speedo & rev counter.
40inches
posted on 29/4/13 at 06:19 PM Reply With Quote
Oil pressure, water temp and volts. Fuel gauge on Acewell
