henryc
posted on 27/5/13 at 12:37 PM |
Steering wheel spacer and rear brake caliper bracket group buy?
Hello All,
I'm about to get a steering wheel spacer and some rear caliper brackets made and wondered if anyone else was interested in a group buy?
I'm yet to get quotes, but the places I use have been very reasonable previously, but would help if I know roughly how many folks would be
interested (if any) so I can get an accurate quote.
Details:
Steering wheel spacer:
Machined from solid Ally, 6 x 5mm holes on 70mm PCD, hole in the centre for weight reduction, 25mm long (but can be longer)
Rear caliper hanger:
6mm thick steel (laser cut to shape), bolts onto the back of the axle flange (for an English mk2 Escort axle), uses a Scorpio rear caliper (I think
Sierra is the same or similar), will find out what disks are the right size to put on. May be a a few weeks before I get these made as want to make
sure it all works properly first.
Henry.
Never stop tinkering
