Author: Subject: Vauxhall viva pcd to ford pcd adapters
Werner Van Loock
posted on 3/6/13 at 05:56 PM Reply With Quote
Anyone know where to get adapters to fit ford wheels to vauxhall viva hubs?
I've got a viva front uprights and hubs but have a english rear axle.
So would like to fit 4 wheels that look the same.
2 possibilities: fit adapter that go from the 4x4" to 4x108 or replace the front end by escort uprights and brakes. Though the viva setup is nice and light.
http://www.clubstylus.be
r1_pete
posted on 3/6/13 at 06:05 PM Reply With Quote
How about re drilling the Viva hubs 45 degrees from the originals?
grassracer
posted on 3/6/13 at 06:17 PM Reply With Quote
Try Berrisford Chassis and Components....does an alloy hub to fit Viva stub axle drilled for both Ford and Vauxhall, simply fit studs to the holes required.
Werner Van Loock
posted on 3/6/13 at 07:19 PM Reply With Quote
The viva hub outer diameter is not large enough for drilling the 4x108
johnH20
posted on 5/6/13 at 07:07 PM Reply With Quote
I am in much the same position as you, GM front end and Ford rear. I decided that since front and rear wheels were going to be different rim widths there was no point in worrying about hub interchangeability. My wheels are Compomotive CRX and look identical, just ordered different stud PCDs.
Werner Van Loock
posted on 27/6/13 at 06:44 PM Reply With Quote
Getting grey hair here now.
Got a pcd adapter from berrisford, turns out it is 4x100 pcd to 4x108pcd while the viva hubs are 4x4", so bought some wobble nuts M12x1.25 but you guess right, the studs are 7/16 unf. Argh!
Searching for 7/16 unf wobble nuts, no chance
So got 3 routes now:
-forget the whole adapter thingy and buy 4x4" wheels for front and 4x108 rears (can't use the wheels i have then )
-replace the 7/16 unf studs with M12x1.25 studs (possible drilling out the stud holes )
-Get a new hub machined by berrisford with 4x108 pcd (probably most expensive)
Too many solutions and already put too much effort in the wheels.
[Edited on 27/6/13 by Werner Van Loock]
scimjim
posted on 27/6/13 at 06:53 PM Reply With Quote
Would either of these options be cheaper than new wheels or hubs and simpler than changing the studs?
1. Have adaptor plates (4x4" to 4x108mm) made
2. Have 7/16" UNF wobble nuts made
Love the wheels BTW
[Edited on 27/6/13 by scimjim]
KJK
posted on 27/6/13 at 06:59 PM Reply With Quote
You can redrill to ford pcd it is close but i had no problems
posted on 27/6/13 at 07:02 PM Reply With Quote
RWD Kadette/Chevette/Ascona hubs may fit the Viva stub axles that should give you a 100mm PCD using bolts rather than 4" with 7/16" studs which should be easier to make adaptors for
Werner Van Loock
posted on 27/6/13 at 08:07 PM Reply With Quote
Are you sure you used viva hubs? The studs are already near the edge, adding about 3.5mm to each stud outwards is really on the edge.
I can also always drill to 4x100 off course, didn't think of that one yet
Thanks for thinking here with me, still is the best forum on the net. (time for a new donation)
KJK
posted on 28/6/13 at 08:47 PM Reply With Quote
Yes viva hubs, it was about 10 years ago we just redrilled the stud holes next the existing ones because you can,t do it at 45 degrees
posted on 28/6/13 at 09:23 PM Reply With Quote
Are you 100% sure we used Viva on Imp front disc conversions using 10.25" Magnum discs and from memory drilling t PCD of 4.25" would be a bit near the edge.
I found this
http://i56.photobucket.com/albums/g185/moshty/20130113_232902.jpg
