Author: Subject: Curved fan blade direction
richardm6994
posted on 20/7/13 at 12:37 PM Reply With Quote
I have a push / pull fan.
When the fan is spinning, which direction should the curved blade be pointing?
I think it is the tips of the blades that should be trailing and the curve leads but I just wanna check
gremlin1234
posted on 20/7/13 at 12:44 PM Reply With Quote
they usually have an arrow on the hub showing intended direction
rdodger
posted on 20/7/13 at 12:52 PM Reply With Quote
Curved blade fans should turn with their tip leading.
In terms of performance, straight blade fans are better. Curved blades reduce noise.
Interesting explanation
http://www.daviescraig.com.au/Straight_vs__Curved_Fan_Blades___Dispelling_the_Myth-news.aspx
[Edited on 20/7/13 by rdodger]
richardm6994
posted on 20/7/13 at 01:30 PM Reply With Quote
So as it rotates, the tips of the blades are ahead of the curve? Are you certain this is correct?
I'm in the garage now and testing both and it's hard to tell the difference but the tips behind the curve seems slightly better.
I'm so confused!!!
dave r
posted on 20/7/13 at 03:03 PM Reply With Quote
all the fans i have tried like that, there is a vast difference between right way and wrong way
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
rdodger
posted on 20/7/13 at 05:41 PM Reply With Quote
Yes basically it looks wrong but the tip should curve in the direction of the rotation.
The one here would rotate clockwise.
http://www.quillertriumph.co.uk/Quiller/Parts/accessories/coolingfans.htm
sebastiaan
posted on 20/7/13 at 09:49 PM Reply With Quote
Sorry, but that is wrong. The blade tips should be trailing on high skew (= "banana" type blades. Like so (sorry about the large pic):
rdodger
posted on 20/7/13 at 10:17 PM Reply With Quote
That's really odd. I had curved fans on my last kit and the manufacturer instructed me to run them tip first.
Perhaps different ones run in different directions?
posted on 24/7/13 at 11:00 PM Reply With Quote
surely it is the angle of the blades that matters - it cojld be possible the angle on those 2 curved blade fans are different?
I mean if the fan blades were flat, it would make no difference whcih way round they turned ~????
sideways view of blade: / ->> pushes air downwards
adithorp
posted on 25/7/13 at 06:39 AM Reply With Quote
Think this is correct. The curveed blades rotate differently from different makers.
Look at the blade shape. They'll be curved in cross section. Leading edge will be the shallower angle (almost 90' to the air-flow) and the angle increase towards the trailing edge.
http://jpsc.org.uk/forum/
posted on 25/7/13 at 07:36 AM Reply With Quote
As adithrop says the is the shape of the cross-section of the blade that matters, easy way to work it out at is the leading edge of the blade should smoothly scoop up stationary air. The fan blade scoops up the stationary air and should smoothly accelerate it, so leading edge of the blade has a shallow angle and the trialling edge a more "coarse" angle almost parallel to the direction the air is flowing in.
[Edited on 25/7/13 by britishtrident]
