Author: Subject: FS : Pinto 2.0 205 Engine, Type 9 Gearbox, Bike Carbs
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 16/10/13 at 07:46 PM Reply With Quote
For Sale :
Pinto 2.0 205 Block With Kent Cam, Bike Carbs, Shortened sump, Type 9 gearbox, prop shaft, manifold, engine mounts for an Indy.
It was dyno'd in April this year with 117.5hp (see attached dyno output) - then it had a kent cam fitted.
Great little engine, starts on the button.
Many many more pictures Here
Video of the engine block running here
205 Engine Block - £350
Bike Carbs & Inlet Manifold - £250
Type 9 Gearbox - £250
Exhaust Manifold - £95
Prop shaft for Indy - £75
Will take £850 for the whole lot if taken together as it's currently all in one piece.
I've also got an aluminium bonnet for an Indy with the exhaust and air filter cut out if you're interested.
Edit to add: Just found a receipt for some engine work done in July this year. Head skim, new plugs, cambelt etc. here
[Edited on 16/10/13 by Barkalarr]
sjmatthews
posted on 16/10/13 at 08:01 PM Reply With Quote
U2U sent
I'll be in the garage dear!
djaques
posted on 16/10/13 at 09:14 PM Reply With Quote
Do you have any photos of the bonnet?
bumpy
posted on 19/10/13 at 07:24 AM Reply With Quote
U2U sent
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 22/10/13 at 09:53 PM Reply With Quote
Updated the sold items
205 Engine Block with Kent Cam & Shortened sump, Radiator, Coil, Starter Motor, Flywheel, Clutch, Engine mounts - £350
Bike Carbs & Inlet Manifold + air filter - £250
Exhaust Manifold - SOLD
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 31/10/13 at 02:31 PM Reply With Quote
205 Engine Block with Kent Cam & Shortened sump, Radiator, Coil, Starter Motor, Flywheel, Clutch, Engine mounts - SOLD
Bike Carbs & Inlet Manifold + air filter - SOLD
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 31/10/13 at 02:43 PM Reply With Quote
Pictures here:
Pic 1
Pic 2
Pic 4
