Author: Subject: Fuel Injector Rates
posted on 25/10/13 at 08:18 PM Reply With Quote
Fuel Injector Rates
Evenin
Picked up a set of individual throttle bodies that came with 4 Weber IWP042 injectors. T'internet states these will flow 240-ish cc per min and are stable up to 5 bar (taking them up to 300-ish cc per min).
I'm fitting the TB's to a standard C20XE... going by the various reports out there, I should expect the red-top to make around 195 bhp with a set of TB's.
Can anyone advise if these injectors are man enough for the job?
It's Evolution Baby!
big-vee-twin
posted on 25/10/13 at 08:35 PM Reply With Quote
This should help link
http://www.triangleltd.com
posted on 25/10/13 at 08:40 PM Reply With Quote
Cheers BVT! That calculator suggests mine won't do... I need 320cc per min injectors.
big-vee-twin
posted on 25/10/13 at 08:59 PM Reply With Quote
I'm using Bosch white giants which do 375cc
silky16v
posted on 26/10/13 at 07:23 AM Reply With Quote
Standard XE won't do 195bhp with throttle bodies more like 175-180bhp run your fuel pressure at 3.5bar and those injectors will be fine
Dusty
posted on 26/10/13 at 07:54 AM Reply With Quote
Stan Weiss has put up injector flow tables here which are the most comprehensive I have found on the web. Here. They also suggest that your injectors are not up to the job. 360ml/min will give about 52bhp per injector and should be about right. He lists your injectors as good for 33.7 BHP each at 80% duty cycle for engine with a BFSC of .52
[Edited on 26/10/13 by Dusty]
jeffw
posted on 26/10/13 at 10:09 AM Reply With Quote
Depends how far into the duty cycle you want to go....they will be pretty much flat out with no headroom at all.
Volvorsport
posted on 26/10/13 at 10:22 AM Reply With Quote
volvo b230ft .... 330 cc/min on a 4 cylinder , about right and on 3 bar too.
saab are rate a bit higher on the 2.3 versions...
peak and hold tho , so youll need resistors ..
www.dbsmotorsport.co.uk
getting dirty under a bus
Uphill Racer
posted on 30/10/13 at 01:25 AM Reply With Quote
When I made up my injection system I used Graham Bell’s calculations.
I also knocked up a system to check flow rates of the injectors at a given pressure.
Accepting that yours do what they recon they do and the HP figures are as silky suggests my calcs agree with his for what it is worth.
daveb666
posted on 30/10/13 at 08:27 AM Reply With Quote
A bit off topic but I've had 2 'standard' XEs with Jenveys and both were over 200bhp; 205 and 209bhp respectively.
