Author: Subject: Lead Replacement Additives
davidimurray
posted on 8/11/13 at 12:38 PM Reply With Quote
As i'm not sure if my Pinto head has been converted to unleade it looks like I am goign to need to use an additivie to be on the safe side. Any reccomendations on best/cheapest to use?
Dave
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
TrophyJem
posted on 8/11/13 at 12:52 PM Reply With Quote
Millers is what I've used in my 2.1 Pinto since leaded fuel became unavailable.
andylancaster3000
posted on 8/11/13 at 12:58 PM Reply With Quote
I use Millers CVL in the single seater engine (pinto). This is supposed to be the pukka one but it is £8 a bottle and this only stretches to 20l :O
I understand Miller VSP is cheaper alternative if its not going to be under sustained high-load. Not sure on other brands.
wicket
posted on 8/11/13 at 09:50 PM Reply With Quote
I've used Millers VSP in my Kent engine for 7 years and had no problems; only road use though.
Dusty
posted on 8/11/13 at 11:01 PM Reply With Quote
Why not check on the exhaust manifold side of the head to the rear of the number 4 spark plug for any stamped letters. These would be P, PP, R, RR, or L for an unleaded head. In addition any injection head with the egg/ cam lobe shaped inlet ports will be unleaded.
[img] unleaded2.0
unleaded2.0
[/img]
[Edited on 8/11/13 by Dusty]
