Author: Subject: Obtaining v5 for donor
richwill
posted on 16/11/13 at 12:47 PM Reply With Quote
I bought a part built kit from a guy last year which I plan to make a start on this winter. However I don't have the v5 for the donor. I do have the vin plate and a section of steel from the car with the chassis number stamped on.
I do not know what the registration number was when the donor was on the road.
What are the implications I may be facing on registering this kit once it is finished?
I am sure many of you have been through this before.
Thanks Rich
prawnabie
posted on 16/11/13 at 12:55 PM Reply With Quote
You will be issued with a Q plate I believe.
Where I work at Renault, we can search a chassis number to get a reg, maybe you can find someone at Ford (I assume that is the donor) to do the same?
Once you have the reg you can fill out a V62, get a new logbook and go for an age related plate.
Shaun
richwill
posted on 16/11/13 at 01:03 PM Reply With Quote
Thanks Shaun. I thought I may have to go for the Q plate. However I may be able to get someone to search the chassis number. I had tried doing that on the web but got nowhere so assume manufacturers have a different system.
prawnabie
posted on 16/11/13 at 01:08 PM Reply With Quote
Yes most manufacturers use in house systems, most of the internet based ones use a reg number to search DVLA information.
loggyboy
posted on 16/11/13 at 01:12 PM Reply With Quote
Q plate or buy another donor (or just v5 with vin plates etc)
Mistral Motorsport
