Author: Subject: Finished Dashboard
SteveWallace
posted on 22/2/14 at 01:46 PM Reply With Quote
Finished Dashboard
I'm now on to the final run in to IVA, so I'm doing final fits. Exhaust maker booked for three weeks time and then off to IVA. This is my finished dashboard - quite pleased with the way that its turned out. ETB gauges by they way.
finished dash 1
finished dash 1
finished dash 3
finished dash 3
finished dash 2
finished dash 2
davidimurray
posted on 22/2/14 at 02:09 PM Reply With Quote
Looking good.
Are you using the steering wheel horn push?if so you might need to put the horn symbol on for iva.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
posted on 22/2/14 at 03:53 PM Reply With Quote
Very smart! The ETB gauges always look good IMHO.
Should be on the road at exactly the right time of year too.
NeilP
posted on 22/2/14 at 05:33 PM Reply With Quote
That looks the absolute business Steve - great job - tax disc soon!
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
ashg
posted on 22/2/14 at 05:49 PM Reply With Quote
are you sure you have enough radius on the underside of the dashboard it looks a bit borderline, mine failed with a very similar style layout.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
SteveWallace
posted on 22/2/14 at 06:16 PM Reply With Quote
I'm not using the steering wheel horn push, I've installed a Savage one (you can just see it to the right of the steering wheel)
wrt the radius of the bottom of the dash, I've used 20mm radius plastic pipe, slotted and recessed into the MDF and then covered with two layers of material, so should be well over the 19mm requirement. There is a strip of plywood (about 1" cross section) glued to the back of the MDF that the pipe is screwed onto for extra strength.
dashboard edging
dashboard edging
back of dash
back of dash
Good comments though. I'll do the usual picture hungry post after the exhaust has been fitter as a pre-IVA check.
