Author: Subject: VW/Audi Rear Calipers - Anyone used them
mccsp
posted on 31/3/14 at 08:54 PM Reply With Quote
I have a leaking rear caliper (sierra) and I am reluctant to go the seal kit route in case it is unsuccessful first time. Following Ben's response to the following post:
http://www.locostbuilders.co.uk/forum/viewthread.php?tid=190063&page=1#pid1599147
I am contemplating the switch from sierra rear calipers to vw/audi units. Just wondering if anyone else has done this on a Luego and whether or not there are any pit falls or added benefits?
I already have everything I need for the sierra calipers already, but a new set and new sliders will set me back £200 (Rally design), can be done cheaper, but If I could switch to the audi/vw type for comparable price, I would jump at it.
Rally Design Calipers and sliders (new):
http://www.rallydesign.co.uk/product_info.php?products_id=13593
Cheapest remanufactured calipers (£50 plus potential for £15 back for old calipers):
Rear Right Brake Caliper To Fit FORD SIERRA GRANADA SCORPIO (CAR551R) | eBay
I have found a set of the audi a3 calipers (no sliders) for £100
AUDI A3 &' AUDI TT - PAIR NEW REAR BRAKE CALIPERS - 1J0615423/1J0615424 BCA067A
They use the smaller 4mm cable fitment
Any thoughts greatly appreciated
Why do it the easy way, when I can do things my way!
Ben_Copeland
posted on 31/3/14 at 09:01 PM Reply With Quote
2004 SEAT LEON CUPRA ALLOY REAR BRAKE CALIPERS &' MATCHING DISCS
£49.00 inc sliders and postage.
Ben
Locost Map on Google Maps
Enter Your Details Here
mccsp
posted on 31/3/14 at 09:13 PM Reply With Quote
There was a Ben Copeland who used to race with his dad and brother.
Will be having a measure up tomorrow evening. Thinking this sounds like a win win as I have no plans to drop to anything smaller than 15's. What are the internal diameter of your rims? I have absolutely no idea whether my wheels offer large or small internal diameter vs other wheels (Wolfrace, can't remember the model off of the top of my head).
mccsp
posted on 31/3/14 at 09:22 PM Reply With Quote
What handbrake cable did you use?
Ben_Copeland
posted on 31/3/14 at 09:52 PM Reply With Quote
Not sure about the wheels, but just a thought..... I have team dynamics alloys and et16 offset. I'm not sure if sierra offset wheels fit over them tbh
Sierra handbrake cable, cut down to the right length and a cable end fitted to the cut end.
Ben
mccsp
posted on 31/3/14 at 10:17 PM Reply With Quote
I need to double check but think I have ET38, which by my logic means a bigger clearance to the spokes.
Ben_Copeland
posted on 31/3/14 at 10:24 PM Reply With Quote
No, other way round I'm afraid. Et 16 is wider than et 38.
Ben
mccsp
posted on 31/3/14 at 10:39 PM Reply With Quote
Brain fade moment, Doh! Cheers
russbost
posted on 1/4/14 at 07:54 AM Reply With Quote
Just something else to be aware of, most late VAG rear calipers such as from the MkIV Golf & onwards have a 12mm entry hole for the brake hose, so you will probably need to replace hoses, or at a minimum if you already have braided hoses, one end of them if you still have adequate length.
mccsp
posted on 2/4/14 at 11:56 AM Reply With Quote
Ben,
All the vw/audi rear disc installations are only 232mm. I presume the increased disc size you are running is accommodated by a different mounting position as a result of the original sierra position?
I don't suppose you have any photo's of your set-up?
Ben_Copeland
posted on 2/4/14 at 12:00 PM Reply With Quote
Yes, basically with standard sierra mountings you need the bigger discs.
I don't currently have a pictures I don't think. I'll have a look. Otherwise i'll pop some up during the week if I get a chance in an evening.
Ben
