Author: Subject: Fireblade 919 no spark
Nurburg2006
posted on 4/4/14 at 09:01 AM Reply With Quote
I've been doing the wiring on the blade engine but I havnt got a spark I've got power to the coils but that's it all the wires are connected when I test the ecu plug not all are live or earthed. Any help would be good. My ecu has 12 wires if that helps. Cheers
[Edited on 4/4/14 by Nurburg2006]
r1_pete
posted on 4/4/14 at 09:07 AM Reply With Quote
IIRC you need to ground clutch sidestand etc inhibitor switch wires, again, from memory I think all these are green with various tracers.
Have you a circuit diagram? I may have a jpeg somewhere...
Nurburg2006
posted on 4/4/14 at 09:55 AM Reply With Quote
Thanks for your reply I have a diagram for it cheers all green wires etc to ground the engine came out of a kit car so most of the wiring is joined up so it should have been a straight forward job to plug and play.
carpmart
posted on 4/4/14 at 11:27 AM Reply With Quote
What have you done with the pink wire?
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
Nurburg2006
posted on 4/4/14 at 06:27 PM Reply With Quote
I don't have a pink wire. .??
Doctor Derek Doctors
posted on 4/4/14 at 06:59 PM Reply With Quote
Stupid question but have you actually got an earth strap to the engine.... It's quite easy to forget to connect the big black cable after hous of fiddling with tiny wires!
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
posted on 4/4/14 at 07:00 PM Reply With Quote
Just realised that if the starter is turning then you must have an earth strap.
www.t89.co.uk
callan@t89.co.uk
Nurburg2006
posted on 6/4/14 at 07:48 PM Reply With Quote
Still no spark any help would be good. Cheers
Nurburg2006
posted on 9/4/14 at 08:05 PM Reply With Quote
Bump
