Author: Subject: Rear toe in mm - where is it measured from?
james h
posted on 16/4/14 at 05:08 PM Reply With Quote
As above.
I'm about to shim my left rear hub carrier to adjust the toe. Searching the forum I found procomp recommends 1-3mm of toe in, and sorting the thrust alignment.
The 1-3mm toe measurement - what point of the wheel/tyre combination is this measured at? Wheel edge? Tyre edge? My wheels are 15". (195/50/R15).
James
ali f27
posted on 16/4/14 at 05:47 PM Reply With Quote
Wheel edge front and back of wheel
yellowcab
posted on 16/4/14 at 06:00 PM Reply With Quote
As above, at rims
james h
posted on 16/4/14 at 06:08 PM Reply With Quote
I had an inkling it might be that. Annoying because I don't know if that is for 13" or 15" wheels!
james h
posted on 16/4/14 at 06:11 PM Reply With Quote
Although when I think about it, toe in at 6.5" radius and 7.5" radius will be similar enough that I could dial in 1.5mm at 13" wheels and be only slightly more with 15" wheels. If that makes sense?
Matt21
posted on 16/4/14 at 06:30 PM Reply With Quote
sorry to hijack....
but, where do you put the shims?
mine needs doing as one side is something like 1mm out and the other 4mm in!
james h
posted on 16/4/14 at 07:02 PM Reply With Quote
They go between the upright and the hub carrier. There are four bolts holding the hub carrier onto the upright, the shims fit on these
I say shims, I've used m10 washers as mine was so far out (my fault, not MK's).
ali f27
posted on 16/4/14 at 07:24 PM Reply With Quote
rim size has nothing to do with toe in
posted on 16/4/14 at 07:34 PM Reply With Quote
??? Since when?
Matt21
posted on 16/4/14 at 07:38 PM Reply With Quote
surely it would?
if you have 2 20ft bars and had them angled so that one end was 0.5ft closer together than the other end
and two bars that are 1ft long that are also 0.5ft closer,
the angles of each would be different, greater for the shorter bars?
same principle but different numbers and units
james h
posted on 16/4/14 at 08:10 PM Reply With Quote
Some phat 30" rims will have the same angle of toe as 13" minilites but the toe in mm will be different, shirley?
ali f27
posted on 16/4/14 at 08:38 PM Reply With Quote
Well that stired it up a bit
SPYDER
posted on 16/4/14 at 09:47 PM Reply With Quote
Originally posted by james h
Some phat 30" rims...
SCOOP! Sneak preview of MEV's latest creation to be unveiled at Stoneleigh!
Nice one Stuart!
