New Topic New Reply
Author: Subject: What's the best grease for suspension bushes?
Sloan85
posted on 18/4/14 at 08:47 AM Reply With Quote
When assembling my suspension I used silicone lubricant but it was a spray. Now it is creaking quite badly so I need to strip it all down to re-grease.
I now have a proper silicone grease but was wondering if there is anything better that I should be using.
[Edited on 18/4/14 by Sloan85]
http://mkindygsxr.blogspot.co.uk
Matt21
posted on 18/4/14 at 08:51 AM Reply With Quote
i would just use the silicone grease, or just multipurpose
Razzakit
posted on 18/4/14 at 09:13 AM Reply With Quote
If you need grease let me know i may be able to help��
Smoking Frog
posted on 18/4/14 at 09:39 AM Reply With Quote
I used molybdenum disulphide grease. It's been recommended on here several times.
posted on 18/4/14 at 10:55 AM Reply With Quote
Of which CV joint grease is the best grade
ReMan
posted on 18/4/14 at 11:41 AM Reply With Quote
Just normal greasy grease for me, (Convert from coppaslip, that just dries out)
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
Mr Whippy
posted on 18/4/14 at 11:45 AM Reply With Quote
normal black moly grease is great as it's unaffected by water, I use it as underseal too
adithorp
posted on 18/4/14 at 12:20 PM Reply With Quote
I use red rubber grease. It doesn't dry out and it's lot less messy tham molly grease to use
http://jpsc.org.uk/forum/
Slimy38
posted on 18/4/14 at 01:00 PM Reply With Quote
I believe coppaslip is ever so slightly abrasive as well?
big-vee-twin
posted on 18/4/14 at 05:20 PM Reply With Quote
Use moly grease normal grease has petrol in it which rots the polybush.
http://www.triangleltd.com
blowden86
posted on 3/5/14 at 12:29 PM Reply With Quote
Red rubber grease James! No noise at all from mine
My MK Indy R GSXR 1000 Build Diary: http://www.suma-uk.com/indy/
New Topic New Reply
