Author: Subject: Sierra diff needed North East
gaz05
posted on 18/4/14 at 04:11 PM Reply With Quote
Getting close to booking IVA so today I put the car on stands and ran it up to set the Speedo up. When I change gear there is an almighty noise coming from the diff. I know it's possible it's because there's no load on it but I think it's shot. I'm taking it out to strip but was wondering if anyones got one lying about. 7" ,3.62 ,non Lsd ,push in shafts. Cheers
RWD Focus
posted on 18/4/14 at 05:16 PM Reply With Quote
Ive got a very good 3.92 push in shaft diff. Nr Leeds if any good to you.
Wadders
posted on 18/4/14 at 08:30 PM Reply With Quote
Give it a run on the road before you pull it apart, they always sound paggered when on axle stands.
Matt21
posted on 19/4/14 at 06:35 AM Reply With Quote
I have a 3.62 open diff, has bolt on shafts but im sure they just pop off so you can use push ins?
very good condition, only took it off to swap for an lsd
only problem is, im offshore untill 29th
im from TS14, can meet you halfway or something if needs be
peter bland
posted on 19/4/14 at 11:41 AM Reply With Quote
Home on Monday,3.62 , 7" push in shafts ,non LSD, North Shields !!!
gaz05
posted on 19/4/14 at 01:51 PM Reply With Quote
Champion!! how much mate. I'll come and get it Monday
peter bland
posted on 19/4/14 at 05:42 PM Reply With Quote
You have u2u.
