Author: Subject: mini wiper motor wiring
simon88
posted on 20/4/14 at 03:28 PM Reply With Quote
Hi guys, I've bought a mini cooper wiper set and just trying to wire it in (only £45 for whole kit)
I managed to get it working on slow intermittent but when I move it to fast it blows the fuse on the 12V going to the wiper stalk, the stalk itself has 4 wires single wipe, 2 intermittent settings and windscreen wash.
Can anyone fill in the blanks? I've included a wiring diagram of how I have it wired in atm, and why the fuse would blow when upped to fast intermittent.
thanks in advance
turnipfarmer
posted on 20/4/14 at 04:11 PM Reply With Quote
Wiring for my Lucas 14W motor to Sierra stalk is...
Top centre - earth (brown)
Upper right - parking brake (brown/white) to pin 31b1 on stalk connector
Lower right - parking supply (black/purple) to pin 54 on stalk connector
Upper left - slow speed (red) to pin 53b on stalk connector
Lower left - fast speed (green) to pin 53 on stalk connector
HTH
simon88
posted on 20/4/14 at 06:13 PM Reply With Quote
right just went out to play around with the wires and got it wired up fairly similar, it doesn't blow the fuse now, but all I have is off and speed 1 but nothing else will work I think it maybe a faulty wiper stalk as I used a fluke and tested the wires when the stalk was set to different positions and only got no resistance on speed 1.
It's a capri mk3 stalks I do believe, anyone know what the wires are theres only 4 of them. or alternatively what aftermarket stalks would look nice lol?
turnipfarmer
posted on 20/4/14 at 07:45 PM Reply With Quote
As far as I know, the standard Lucas 14W motor (if that's what you have) doesn't have an intermittent wipe function.
I wasn't expecting my intermittent wipe to work, and indeed it doesn't.
It doesn't bother me, but I think you can mod the wiring somehow, or buy some sort of add-on if it's a 'must have' for you.
Fraid I don't know the Capri stalk at all, but if you think it might be faulty, there's a number on ebay for under a tenner.
Having a "single wipe & 2 intermittent settings" sounds a bit strange. Are you sure your "single wipe" isn't really the intermittent, and the "2 intermittent settings" are continuous speeds 1 & 2 (slow & fast)? I would expect that to be the norm, but as I say I don't know the Capri stalk, so you may well be right.
simon88
posted on 20/4/14 at 07:56 PM Reply With Quote
sorry I meant 2 speeds slow and fast not intermittent. yeah I think the stalk is definitely faulty,
I do like the look of the escort mk4 stalks seen them on ebay fairly cheap but this can wait till after the MOT it cleans the screen and I have a separate button for the windscreen wash so it'll do for now
