Author: Subject: Type 9 ratios
mookaloid
posted on 9/11/04 at 09:10 PM Reply With Quote
Type 9 ratios
Does anyone know where I can find out which gear ratios were fitted to the various type 9 gearboxes?
Mark
lugo35
posted on 9/11/04 at 09:21 PM Reply With Quote
search forum topics have been posted b4 cheers andy
lugo35
posted on 9/11/04 at 09:22 PM Reply With Quote
well i think they have
Mark Allanson
posted on 9/11/04 at 09:50 PM Reply With Quote
I have found no variance fron these ratio's
1st 3.65
2nd 1.97
3rd 1.37
4th 1
(5th) 0.82
mookaloid
posted on 9/11/04 at 09:58 PM Reply With Quote
Thanks Guys,
I should have looked a bit harder!
It seems the close ratio box (for V6)has a taller 1st gear (3.36) which is what I wanted to know
Mark
MikeR
posted on 9/11/04 at 10:51 PM Reply With Quote
don't forget the v6 gearbox has a longer input shaft (by about an inch) so needs either a spacer (ala caterham) or an expensive modified input shaft or an angle grinder taken to in (thats a joke!)
Also, the input shaft is stronger as it has an extra bearing or something on the v6.
