<<  1    2    3    4  >>
Author: Subject: progress at last
garyt
posted on 17/5/14 at 05:59 PM Reply With Quote
progress at last
well here we have some progress at last, round 1 saw my lill car being claimed as an asset in my divorce so now I have a new wife and started on a new car !!! Haynes roadster, mx5 based
[img] Description
[/img]
garyt
posted on 17/5/14 at 06:01 PM Reply With Quote
[img] Description
[/img]
garyt
posted on 17/5/14 at 06:09 PM Reply With Quote
floor and back panel ready to go on tomorrow, make up column mounts, then start on the wishbones
bye the bye got all the mx5 wishbone plates cut by craig at plazcutz for £45 posted no interest just satisfied customer, plates from 5mm plate as per Saturn drawings will add pic of these if anyone wants.
garyt
posted on 18/5/14 at 04:35 PM Reply With Quote
ha ha, floor and back panel on ,
[img]http:// Description
[/img]
garyt
posted on 8/6/14 at 04:14 PM Reply With Quote
front wishbones made couldn't resist putting her on her feet (front ones anyway) now for the other end... anyone have the measurement rear top wishbone mount hole centreline to upright mounting hole centreline Saturn / mx5 mk1
regards Gary (''
[img] Description
[/img]
pg]105555[/pg]
[Edited on 8/6/14 by garyt]
garyt
posted on 8/6/14 at 04:19 PM Reply With Quote
another pic
[img] Description
[/img]
Slimy38
posted on 8/6/14 at 04:44 PM Reply With Quote
Somewhere on the internet is a drawing of the back end of a Saturn, someone posted it on here in response to one of my questions but I cannot find it now. I'll keep an eye out for it and post if I find it.
Personally I'm going to fit my diff, driveshafts and uprights and measure to suit. I just don't trust the Saturn build guide, and while I'm following their general principles, I'm double checking all the measurements. I've already found the the upper crush tube in my rear upright is only 54mm, whereas the wishbone design is for 67mm.
garyt
posted on 8/6/14 at 04:55 PM Reply With Quote
Hi Thanks , I had planned to do much the same put diff ,driveshafts, bottom wishbones (made), hub together then measure up.
I got craig at plazcutz to do the plates as per drawings and on the dry run I found the difference in the rear upright top mount so welded the U bracket to suit. I also put inserts/ rosejoints onto the outboard end of the rear lowers , neater and gives the camber adjustment.
thanks again gary
garyt
posted on 26/6/14 at 06:34 PM Reply With Quote
[img] Description
[/img]
garyt
posted on 26/6/14 at 06:39 PM Reply With Quote
so here are a couple of pics , she's now on 4 feet not after some panic popped the diff driveshafts in and built up the back end to discover about 15 deg camber... don't panic... measure and re measure , modify the lower wishbones and put back together.. breathe and 0 deg with the adjusters all the way in
Also splashed some paint on to keep the rust bug away. must admit felt real chuffed seeing her sat there
[img] Description
[/img]
garyt
posted on 23/7/14 at 07:47 PM Reply With Quote
well been doing a bit as I can, and tonight got the heavy mob from work (Trina fed them) and they put my engine and box in for me seriously they picked it up and said where about !! well chuffed now to get on and make up the mounts oh yes and some stiffer front springs . it sure feels good to make progress
[img] Description
[/img]
garyt
posted on 16/8/14 at 05:23 PM Reply With Quote
well made some progress fuel / brake lines in , m/c's in, pedal box in, got some bodywork so couldn't help myself had to try it on ???? the car..
oops engine will have to go down and over a "wee tadge" (flexible Scottish measurement) as hitting bonnet, will have to redo the engine mounts, not a big job though.
[img] Description
[/img]
garyt
posted on 19/10/14 at 04:26 PM Reply With Quote
here some pics of the progress, sides are made and fitted and I shortened the headlight brackets made the trans tunnel sides and despite measuring and remeasuring goofed the drivers side so will redo next week
need to sort out bonnet catches carry on plumbing in the supercharger and redo the trans side .
at least she is looking proper now. also got my vin from dvla starting to be official aswell. lol.
[img] Description
[/img]
garyt
posted on 19/10/14 at 04:27 PM Reply With Quote
garyt
posted on 19/10/14 at 04:28 PM Reply With Quote
[img] Description
[/img]
garyt
posted on 19/10/14 at 04:29 PM Reply With Quote
[img] Description
[/img]
posted on 19/10/14 at 04:30 PM Reply With Quote
Looks good fella, keep up the good work and keep us posted
garyt
posted on 19/10/14 at 04:35 PM Reply With Quote
cheers, its starting to get real dark early up here and a bit colder now too, the cold I can handle , up the coffee intake but dark ? guess I don't eat enuff carrots. lol. so need to sort some lighting out also got a massive tarp so can rig around to keep the weather out and me in ?
gary
garyt
posted on 15/11/14 at 04:09 PM Reply With Quote
ok so out int cold and damp but got the sc install moving forward sorted out the inlet side and exhaust manifold / downpipe so next mount the intercooler and pipework then going to play with the wiring........
gary
garyt
posted on 15/11/14 at 04:11 PM Reply With Quote
[img] Description
[/img]
dubzter
posted on 15/11/14 at 06:56 PM Reply With Quote
Looking good Gary, whats your plans for the SC, is it an eaton mini cooper charger?
I've read a bit about double throttles for the mx5 charger, are you going down this route?
garyt
posted on 15/11/14 at 10:55 PM Reply With Quote
hi , thanks for the comments , yes its an eaton m45 cooper s charger with the mini by pass valve running dual throttle bodies although the second one has no electronics on it , you can use only 1 but using 2 gives smoother idling , it is set slightly advanced from the "normal" one.
the bypass takes its vacuum from the plenum. As you can see its a bit of a "quart into a pint pot" job , and certainly gets the old grey matter going !
the air filter I've routed to the inlet side at the rear along with the afm, and the air temp will go between the intercooler and main throttle body thus giving a more accurate reading.
the exhaust was the next problem , there was no way the mk2 manifold would fit past the charger, bypass and pipework, so I set to and copied the Miata turbo manifold to a 2.5" down pipe, not the best manifold design in the world but space was at a premium it will be wrapped as well to try and reduce the heat transfer a little.
Next is to mount the intercooler and work out the pipework for it and make and mount a belt tensioner if anyone is considering going this route there are some great write-ups on mx5nutz site
Really cant wait till I get it running.
how about yourself any progress yet?
Gary
dubzter
posted on 15/11/14 at 11:07 PM Reply With Quote
Gary
Sounds great and as you say a bit of a head scratcher.
I've finally bit the bullet and put a deposit down on a Talon MX-5 chassis, wishbones and diff cover, so now on the hunt for the right donor car, I'll probably just build standard mx5 to start of with and then I'm thinking about the SC route after reading the threads on nutz (and will be following your build with great interest). I have a SC on my VW Golf and love the delivery of power it gives.
I'm down in Inverness quite often and wouldn't mind coming for a nose at your build sometime if you are up for it.
garyt
posted on 15/11/14 at 11:34 PM Reply With Quote
hi , your more than welcome any time .
the talon stuff is really good quality and I'm sure you will be happy with it. Yes its best if you can source a donor and strip it, unfortunately I do not have the space for that so merrily shop as I go!! does make it interesting sometimes researching what fits what in the end I opted for the mk2.5 vvt engine with a mk2 5 spd box as I read that the 6 spd had some weak points and questioned the use-ability of the ratios given the lightness of the finished car .
good luck and just shout if I can be of any help
gary
garyt
posted on 23/11/14 at 05:30 PM Reply With Quote
well got a bit done this weekend, got the fuel filter and lines in and done, made and mounted the s/c tensioner,mounted and plumbed the intercooler and mounted the boost sensor, and put some paint on the s/c outlet.
then started stripping back the engine loom to move a couple of things, working back towards the scuttle wiring ... oh fun.... so next weekend is shortening moving and retaping the engine loom
[img] Description
[/img]
<<  1    2    3    4  >>
