Author: Subject: Novice ML7 user needs advice
johnH20
posted on 27/5/14 at 06:42 PM Reply With Quote
Managed to buy an ML7 a couple of years ago. ( Wish I had done it 10 years ago when I retired but that is another story ). I have learned to do basic turning and boring and am now about to attempt tapers, but I aspire to make some intake trumpets with bell mouth openings. How do I do this? Do I need to grind a special tool or is there a trick to use a single point tool to execute a radius in the horizontal plane? I cannot figure this out. For info I have a 4 position turret type tool holder. TIA.
big_wasa
posted on 27/5/14 at 06:57 PM Reply With Quote
If turning between centres you can offset the tailstock.
Or you can use the compound slide.
For the radius you could use a ball turning attachment .
[Edited on 27/5/14 by big_wasa]
robinj66
posted on 27/5/14 at 07:04 PM Reply With Quote
Have a look at this series of videos - Tubelcain - I know the lathe is an Atlas but it's very similar to yours.
Also this may be helpful
theprisioner
posted on 27/5/14 at 09:37 PM Reply With Quote
I thought trumpets spun using a bending technique (tool) while spinning the job?
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
davidimurray
posted on 28/5/14 at 08:15 AM Reply With Quote
Have a look for a "Ball Turning Attachment"
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
designer
posted on 28/5/14 at 08:16 AM Reply With Quote
Trumpets are a lot better spun rather than turned. And a lot quicker.
johnH20
posted on 28/5/14 at 11:23 AM Reply With Quote
Well, I need to look into the dark art of spinning as well, another skill I do not have. Thanks for the advice and links folks.
big_wasa
posted on 28/5/14 at 11:38 AM Reply With Quote
Well if you make a former from alloy you could then lay them up in carbon fibre.
r1_pete
posted on 28/5/14 at 11:53 AM Reply With Quote
This may help with your trumpet design :
Trumpets
Trumpets
Uphill Racer
posted on 3/6/14 at 12:07 AM Reply With Quote
You could also use the former to swage them, that is how i made mine.
