Author: Subject: Zzr1100 high pitch squeeling noise
teegray19
posted on 9/6/14 at 08:42 PM Reply With Quote
New (old unknown) zzr1100 engine in the car... Ran up and down the road all gears work, engine seems ok.. Then a really loud squeeling noise apprears.. I wa thinking something on prop.. Wheels etc.. Nothing seems to be rubbing... Any suggestions!?
Built Formular 27 with 1600cc crossflow, 1700cc 0 miles crossflow, Kawasaki ZZR1100
daviep
posted on 9/6/14 at 09:21 PM Reply With Quote
This is very common, you've run over a cat
Sorry
Davie
dave_424
posted on 9/6/14 at 09:26 PM Reply With Quote
Does it depend of engine RPM or car speed, depress the clutch when going along and see if the squeel goes away
Guinness
posted on 9/6/14 at 09:31 PM Reply With Quote
Is the alternator or starter hot to the touch (hotter than the engine?).
Given they are both a couple of bolts to swap out for your existing known units, I'd start there.
teegray19
posted on 9/6/14 at 09:48 PM Reply With Quote
it was literally a run up and down the road, more digging to be done tomorrow, do you think the starter could be kicking in or engaged a little bit?
il touch both tomorrow and see if they are hot!
it didn't depend on engine speed, just came and went at different speeds. Although i did drive very slow and low rpm cause it was a nasty noise!
the noise did seem to appear just after a gear change... wonder if its a clutch thing? hmm..
kj
posted on 10/6/14 at 08:34 AM Reply With Quote
Glad to see you got it back up and running Tee
Think about it, think about it again and then do it.
teegray19
posted on 11/6/14 at 09:54 PM Reply With Quote
Just to close this off, changed altinator but turned out to be metal dust cover on the center bearing of the prop! Took a lot of head scratching but all sorted and up and running!
Thanks for the suggestions! Not always easy sorting these little things out.
Should always stick to my motto, add more lubrication!
jossey
posted on 12/6/14 at 07:55 AM Reply With Quote
There is always time for lube....
David Johnson
Guinness
posted on 12/6/14 at 05:27 PM Reply With Quote
Pleased you got it sorted.
