spegru
posted on 2/7/14 at 09:18 AM |
Standard Ford MT75 Gear lever mechanism
Hi I need a standard Ford MT75 gear lever extension. The frame bit that is bolted onto the back of the gearbox itself.
The one I've got is from a Transit and it's way too short so I think I need one from a Sierra.
Anyone got one spare?
[Edited on 2/7/14 by spegru]
spegru
posted on 19/10/14 at 08:07 PM |
OK so I got (most of) one of the extension mechanisms but I still need a small widget to connect it all
The Transit mechanism connected the gearlever almost directly to the gear change shaft, via a swivel cup that is bolted directly onto the gearchange
shaft
Since I've now removed the transit style system I need the sierra-style coupling that connects the lever actuator to the gear change shaft.
The only problem for me is that I've never seen one so I cant describe it but I estimate that it can must be a hollow tube about an inch
long!
Can anyone help?
spegru
posted on 19/10/14 at 08:18 PM |
Correction. I've just found a picture of the bit I'm looking for from ebay and it's not tubular
More like square really
spegru
posted on 25/10/14 at 08:54 AM |
bump
spegru
posted on 17/11/14 at 09:06 AM |
Bump
big_wasa
posted on 17/11/14 at 03:56 PM |
They are a bit thin on the ground. But you don't need it either.
just make up a remote gear linkage like the westfield one.
