<<  1    2  >>
Author: Subject: Biuld diary of a st170
Mark100
posted on 17/7/14 at 01:50 PM Reply With Quote
Hi does anyone putting a st170 engine in a 7 have a build diary links to one on another forum etc ???
Thanks i could use the info
posted on 17/7/14 at 02:06 PM Reply With Quote
You can have a look through mine, not been updated since I sold it tho.
Might be something of use to you.
http://mymnrvortx.blogspot.co.uk/
Mark100
posted on 17/7/14 at 03:21 PM Reply With Quote
Nice thanks few good ideas of were to start there
kingster996
posted on 17/7/14 at 03:26 PM Reply With Quote
Coozer - did you get it set up on a rolling road? If so, where - or do you know a good RR company locally?
I used to be indecisive, but now I'm not so sure
slingshot2000
posted on 17/7/14 at 03:35 PM Reply With Quote
I can strongly recommend MacDonald Racing on Maiden Law, between Anfield Plain and Lanchester, for their rolling road expertise.
Regards
Jon
kingster996
posted on 17/7/14 at 03:51 PM Reply With Quote
Thanks Jon
Won't be for a while yet, not even sourced my engine!
neilp1
posted on 18/7/14 at 06:49 PM Reply With Quote
Mcdonald racing wont rr mine. duratec gsxr 1000 tb omex ecu. I took mine to motoscope in Northallerton.
posted on 18/7/14 at 07:23 PM Reply With Quote
Set mine up with the MS myself using an AFR and tuner studio..
Swapped to an Omex and got it set up at at Automark in Stokesly.
http://www.automarkuk.com/
kingster996
posted on 18/7/14 at 07:39 PM Reply With Quote
Good to know there's a few options. Cheers!
BaileyPerformance
posted on 18/7/14 at 08:24 PM Reply With Quote
We'll set it up for you :-)
Not too far to come... And we're cheap!!
www.baileyperformance.co.uk
kingster996
posted on 19/7/14 at 07:47 AM Reply With Quote
Apologies to Mark for the thread 'hijack' !
@baileyperformance - heard good reports about you guys, but at over 4hrs to get there, it's not that close! Besides will be next year by the time I have the IVA sorted and need an RR session
Mark100
posted on 21/7/14 at 11:44 PM Reply With Quote
no problem kingster
anyone in yorkshire got a st170 in a 7 i could pop over to with my cammera and a tape measure
kingster996
posted on 23/7/14 at 10:25 AM Reply With Quote
Thread now 'unhijacked' - as I now too have an ST170 engine! (well, when I pick it up that is)
So, might be picking your brains later on (and Coozer's too)
Main question I have now is what do I need to mate it to my Type9 box (ie which flywheel, clutch, bearing, cable clutch arm etc)?
I'll get on to induction later I guess.
posted on 23/7/14 at 02:49 PM Reply With Quote
You need a 1.8 escort zetec flywheel and a Mk1 Mondeo cover and plate, a CTT133 release bearing from a Capri.
That lot will go under a standard type 9 bellhousing and release fork. Alternatively, a ali RS2000 bellhousing works OK as well.
kingster996
posted on 23/7/14 at 03:00 PM Reply With Quote
Cheers Steve, just the sort of info I was after (and I'm sure Mark won't mind either!)
posted on 23/7/14 at 03:07 PM Reply With Quote
Flywheel for reference...
posted on 23/7/14 at 03:10 PM Reply With Quote
NTDWM!
escort rs turbo efi i zvh zetec turbo efi flywheel with clutch @ pressure plate
Flush?
Ford Zetec billet Steel Flywheel ultra light RWD
[Edited on 23/7/14 by coozer]
kingster996
posted on 23/7/14 at 03:15 PM Reply With Quote
Originally posted by coozer
Flush?
Gulp - not that flush no!
posted on 23/7/14 at 03:30 PM Reply With Quote
Just remembered, a starter motor off cvh or dohc Sierra.
Mark100
posted on 23/7/14 at 10:42 PM Reply With Quote
thanks ladds ill get flee baying for some bits
Mark100
posted on 23/7/14 at 10:44 PM Reply With Quote
forgot to ask these type 9,s does it matter if its long shaft or short as ive seen both advertised or is it just the right bellhousing i need
Mark100
posted on 23/7/14 at 11:51 PM Reply With Quote
so just payed for this is this flywheel and the complete clutch i need spigot bearing ?? got a thrust bearing on order
posted on 24/7/14 at 10:39 AM Reply With Quote
Short shaft IMO.
And yes you need a spigot bearing, unless its a st170 which already has one fitted.
kingster996
posted on 24/7/14 at 11:24 AM Reply With Quote
This any good?
FORD ESCORT LIGHTENED FLY WHEEL FOR GTI
Also, is the clutch for any particular Mk1 Mondeo? (found one for a 1.8 diesel and 2.0 petrol - are they the same?)
[Edited on 24/7/14 by kingster996]
graham-e
posted on 29/7/14 at 02:16 PM Reply With Quote
Mine has a ST170 in it in Berkshire
<<  1    2  >>
