Author: Subject: Help me dismantle my Sierra steering please
bumpy
posted on 18/7/14 at 02:15 PM Reply With Quote
I need to separate the tie bar end from the steering rack.
The Haynes book suggests a pipe wrench, but it doesn't want to budge.
Although the Haynes book doesn't mention it, it looks like the part has been dressed over into a slot.
Can anyone give me advice on how to proceed?
I will try and get some pictures up. Nothing works
[img]https://imageshack.com/i/ewf1ce4fj[/img]
[Edited on 18/7/14 by bumpy]
[img]https://imageshack.com/i/ey68841cj[/img]
There are a couple of pictures in my archive
19sac65
posted on 18/7/14 at 03:18 PM Reply With Quote
Theyre very tight
I use good quality stilsons
Failing that can you carefully grind two flats on it so you can use a spanner
bumpy
posted on 18/7/14 at 04:09 PM Reply With Quote
bumpy
posted on 18/7/14 at 04:52 PM Reply With Quote
Originally posted by bumpy
Thanks for that. I guess I should relieve that burred-over bit first.
I have some big Stilsons, but the Haynes book shows the job being done in a vice. If I do it on the car, could I damage the steering rack with all that leverage?
The book only says 50 ft lbs, so perhaps they have Loctite on them.
Smoking Frog
posted on 18/7/14 at 06:30 PM Reply With Quote
The only way to be sure of no damage is to remove it and put it in a vice. I also tried to undo mine without removing rack. The sensible conclusion is to remove it. Seemed to undo quite easily once in a vice and the turning force is concentrated just on the joint.
CosKev3
posted on 18/7/14 at 09:23 PM Reply With Quote
Or get someone with another pair of grips to hold the rack while you undo the track rod
