Author: Subject: 2011 Fiesta Service light reset
r1_pete
posted on 24/7/14 at 10:25 AM Reply With Quote
Does anyone know how to reset the service light on the 2011 Fiesta?
Daugters is not due till November but its flashing now.
Sometimes there are switch sequences you can use.
Cheers.
Pete.
beaver34
posted on 24/7/14 at 10:40 AM Reply With Quote
Ign on, press brake pedal and throttle at same time hold them down till it clears on he main display where it should be displaying service due
Ben_Copeland
Try this
I've done it twice. Here's the simple, really works way:
1. Stick the key in.
2. Make sure it's in park or neutral
3. Hold down the brake and gas all the way
4. Turn the key to accessory (where everything powers up and the dash lights come on, but it doesn't crank) DON'T CRANK IT!!!!!!!
5. Hold down the pedals until the change oil light (oil can and wrench) disappear. Keep holding just a few seconds more for good measure.
6. Turn off key, then crank it. It should be off permanently now.
[Edited on 24/7/14 by Ben_Copeland]
Ben
Locost Map on Google Maps
Enter Your Details Here
r1_pete
posted on 24/7/14 at 10:42 AM Reply With Quote
Thanks guys, just talked her through that, all sorted.
