Author: Subject: Valve spring compressor
r1_pete
posted on 29/7/14 at 09:49 AM Reply With Quote
Is there anyone in the Sheffield, Rotherham Chesterfield area with a Valve Spring Compressor I could borrow, or bring a cylinder head to your place to pop the valves out? Fairly large valves in a Jaguar XK head.
Cheers.
Pete
owelly
posted on 29/7/14 at 02:43 PM Reply With Quote
If you're just taking them out, use a couple of sockets and a hammer:
Put the head on the bench springs side up. Put a suitably sized socket under the head of the valve to stop it from opening.
Put a socket on a 6" extension on the spring cap. Holding the socket in place with the extension, whack it with a hammer. The collets will jump into the socket. It may take a couple of whacks.
A pillar drill works well to re-assemble!
http://www.ppcmag.co.uk
Nickp
posted on 29/7/14 at 04:55 PM Reply With Quote
I've a couple of different ones you're welcome to borrow. I'm 2mins off M1 J36.
[Edited on 29/7/14 by Nickp]
