Author: Subject: ford sierra front hub washer size help
raptor700
Contributor
Posts 241
Registered 28/2/09
Member Is Offline
Photo Archive Go!
Building: MK INDY R GSXR 1000 K5. Now sold..... Ready for th
posted on 31/7/14 at 10:13 AM Reply With Quote
hi , just had the front ord sierra hubs powdercoated with new bearings and seals just about to torque the 41mm nut up and there is no washer, there wasn one when i bought the hubs and you dont get one supplied in the bearing kit.
does anyone have 2 spare washers?
ford dont make them anymore, does anyone know the size and thickness so i could have a couple lazer cut. thanks in advance
[Edited on 31/7/14 by raptor700]
tims31
posted on 31/7/14 at 10:55 AM Reply With Quote
Where did you get your bearing kits from, I got mine from Firstline and the washers were supplied.
I'll have a look in te garage later and see if I have a couple of old ones...
[Edited on 31/7/14 by tims31]
Build: http://www.martinsfurybuild.co.uk/
raptor700
Contributor
Posts 241
Registered 28/2/09
Member Is Offline
Photo Archive Go!
posted on 31/7/14 at 01:17 PM Reply With Quote
They were just skf ones typical I didn't get any.
If u could have a look that would be great , I wonder If just got a washer for a 41mm nut it may be the same ?
CosKev3
posted on 31/7/14 at 05:10 PM Reply With Quote
I don't think a normal washer will be thick enough, iirc the washer is probably about double the thickness of a normal washer, and it has a locating bit that sits in stub axle and stops it spinning.
Didn't get washers with my bearing kits either.
Might be worth a call to that tvr place kingster linked to on your thread about the grease covers for front hubs
[Edited on 31/7/14 by CosKev3]
raptor700
Contributor
Posts 241
Registered 28/2/09
Member Is Offline
Photo Archive Go!
posted on 31/7/14 at 06:05 PM Reply With Quote
I got some of this caps , pretty expensive but looked good powdercoated .
I might have to get some lazer cut if anyone knows the dimensions .
kingster996
posted on 31/7/14 at 09:10 PM Reply With Quote
Will measure them for you tomorrow if you want.
Hang on, thought you meant caps. Not split my hubs yet.
[Edited on 31/7/14 by kingster996]
I used to be indecisive, but now I'm not so sure
tims31
posted on 31/7/14 at 10:43 PM Reply With Quote
Hi, Sorry been a busy day.
Had a look in the garage for the washers but they weren't where I thought they were. I'll have a look at the weekend when I get more time but as stated above, they are alot thicker than a standard washer, probably about 4mm
tims31
posted on 31/7/14 at 10:52 PM Reply With Quote
Just had a look through my build images and the ones I used had serrations on to lock onto the hub, I think the one with the slot and key is the rear hub and washer...
Hub-washer
Hub-washer
CosKev3
posted on 1/8/14 at 04:08 AM Reply With Quote
Hub-washer
Hub-washer
Ah thats the one! I knew it had someway of not spinning
