Author: Subject: revs slow to fall
b3nny
posted on 1/8/14 at 07:14 PM Reply With Quote
revs slow to fall
Noticed this over the last couple of trips out, once warm the revs seem very slow to fall to idle from around 3k and also now idles at 1k when warm when normally she sits around 900rpm.
Any ideas? She's a 2.0 black top twin 45 webers.
pmc_3
posted on 1/8/14 at 08:20 PM Reply With Quote
Air leak somewhere I would have thought
adithorp
posted on 1/8/14 at 08:28 PM Reply With Quote
That would be my first thought. Check around the inlet manifold.
http://jpsc.org.uk/forum/
Sam_68
posted on 1/8/14 at 08:41 PM Reply With Quote
Check the obvious too - sticky throttle cable, something seized or binding in the linkages or throttle butterflies/shafts?
rick1962uk
posted on 1/8/14 at 09:17 PM Reply With Quote
have you checked the carbs are balanced
jeffw
posted on 1/8/14 at 09:25 PM Reply With Quote
Air leak....
philfingers
posted on 1/8/14 at 10:07 PM Reply With Quote
Not too rich? Could try dropping the idle mixture screws 1/8 turn. Easy to put back if it isn't!
The true home of cars born under the Sylva name - http://jpsc.org.uk/forum
STM Phoenix R1
Sold-Sylva Striker 1300xf, 40s etc
Sold-Sylva Phoenix, 1300xf, BVH, 234cam, 2xDCOE 40s, live axle - 'old school', rally car and a few bikes
b3nny
posted on 2/8/14 at 12:29 PM Reply With Quote
Carbs where balanced only a couple of weeks ago, I'm going to try the idle mixture screw next time I'm out but from what I have read it's more than likely a air leak.
Is there a easy solution to finding this or would a smoke test be advisable?
Sam_68
posted on 2/8/14 at 12:50 PM Reply With Quote
In the olden days, the standard technique was to go around the manifold gaskets/O-rings spraying easi-start or WD40, and when the revs picked up, you knew you'd found your leak.
I've heard suggestions that you can do the same thing with rather more safety and precision by using an unlit blow-torch, with the nozzle played around the joints, but I've never tried it myself.
If you're on Webers, top suspects would be the carb mounting O-rings/misab plates. These are basically service items anyway, so I'd be inclined to replace them (with new mounting rubbers/thackeray washers) before even trying anything else.
bumpy
posted on 2/11/14 at 04:13 PM Reply With Quote
And the answer was?
