Author: Subject: Nearly...
Mr Whippy
posted on 18/8/14 at 06:55 AM Reply With Quote
Nearly...
I took the rocker cover off to do a quick cylinder head swap and got a nasty shock... thought I'd have to do a whole engine swap instead which is a pest if you need the car the next day to go to work! but managed to recover the broken bit and there's no other damage so very lucky indeed.
Can you spot the issue?
[Edited on 18/8/14 by Mr Whippy]
mookaloid
posted on 18/8/14 at 07:20 AM Reply With Quote
Is that a broken cylinder head bolt sticking up between the exhaust valves there?
Mr Whippy
posted on 18/8/14 at 07:31 AM Reply With Quote
yip not sure why it went and fortunately the gasket didn't blow which is amazing, never seen this happen before myself
There was a really small bit of the threaded section sticking out the block when I took the head off and it just spun out no bother so very luckly the block is fine
loggyboy
posted on 18/8/14 at 07:37 AM Reply With Quote
8 valves are missing?
Mistral Motorsport
Mr Whippy
posted on 18/8/14 at 07:38 AM Reply With Quote
I wish
jollygreengiant
posted on 18/8/14 at 09:49 AM Reply With Quote
I wish
It's alright, you've got the regulation 16 valves, just not all in the same place, 8 on the engine and 8 on the work bench.
Grimsdale
posted on 18/8/14 at 09:57 AM Reply With Quote
have you got a photo of the fracture surfaces? i bet it's a fatigue failure due to undertightening / loss of bolt tension.
liam.mccaffrey
posted on 18/8/14 at 10:46 AM Reply With Quote
Might be being a numpty but how would under tightening cause fatigue failure?
Build Blog
Build Photo Album
wilkingj
posted on 18/8/14 at 10:50 AM Reply With Quote
I wish
I got 16 valves in my old car... 8 in the engine, and 8 in the radio!
[Edited on 18/8/2014 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
Mr Whippy
posted on 18/8/14 at 11:04 AM Reply With Quote
I'll take that when I get home, looks a very sharp jagged crack. The bolts have a 14 on the top so may be grade 14?
coyoteboy
posted on 18/8/14 at 12:47 PM Reply With Quote
Combination of factors including, but not limited to:
1) Unloading of clamping force means shear loads are carried by the bolt, not the clamping surfaces.
2) A loose bolt can be subjected to bigger stresses as the materials around can deform more meaning loading isn't axial
3) Stresses about zero seem to be harder on parts than stresses about a raised mean, it's to do with fracture propagation.
[Edited on 18/8/14 by coyoteboy]
Grimsdale
posted on 18/8/14 at 04:07 PM Reply With Quote
In a correctly tightened ideal situation, the bolt clamping force is higher than the force experienced by the joint as a whole, so the bolt never sees a cyclic load, and a fatigue fracture cannot occur.
In an under tightened situation, the load on the joint can be greater than the clamping load exerted by the bolt, so the bolt experiences cyclic loading which, if above the fatigue limit, will allow fatigue failure.
Mr Whippy
posted on 19/8/14 at 06:03 AM Reply With Quote
Hi
Here's a picture of the broken bolt, quite a sharp break and it almost fits back together perfectly. Not sure why it broke though to me it looks like it's been twisting at the time so maybe over torqued?
Grimsdale
posted on 19/8/14 at 08:42 AM Reply With Quote
Yeah, that's fatigue.
The fracture surface is split into two main regions - one planar region and one angular distorted region.
On the planar region you can see circumferential rings, particularly near the outer edge. These are known as beachmarks and are generally indicative of a fatigue crack progressing from the outer surface inwards. As the crack progresses, the effective cross sectional area of the bolt reduces to a point where it cannot withstand the tensile load, and the remainder of the bolt fails by tensile overload.
Undertightening is not the sole cause of fatigue failure of bolts, but it is common. Other factors such as inadequate stiffness of the joint as a whole, loss of tensile loading (head warping, gasket failure etc).
Mr Whippy
posted on 19/8/14 at 11:15 AM Reply With Quote
that's interesting thanks
The Black Flash
posted on 19/8/14 at 10:36 PM Reply With Quote
Seconded - I find this stuff fascinating.
haz87
posted on 20/8/14 at 08:17 AM Reply With Quote
Very informative
