Author: Subject: Rose joint instead of normal ball joint
FERRARIST
posted on 27/8/14 at 08:45 PM Reply With Quote
I'm considering different options for my front lower wishbone, and because it's my first build i rather prefer to ask maybe silly questions than risk my own safety.
I'm using shorten version of the upright pictured below just for this example(used one is shorter)
My question is will 20mm rose joint be strong enough to sustain weight in the front? I know that rose joints works in different direction, but i saw many applications like this. I will redrill upright hole to 20mm as well and strongest bolt used.
Lower arm is 48cm long, damper mounting point is 8cm away from the rose joint and there will be enough play(up and down) so i have no worry about. Seamless 26x3mm tube for wishbone, my plans is total weight of 660kg.
Sam_68
posted on 27/8/14 at 09:23 PM Reply With Quote
It will probably be strong enough, but it's not a good or elegant solution.
Why are you not able to use a ball joint?
If there's no suitable ball joint available, have you considered a spherical bearing in a fixed, machined housing for the heavily loaded bottom wishbone, and use a Rose joint for camber adjustment on your lightly-loaded top wishbone?
drt
posted on 28/8/14 at 03:58 AM Reply With Quote
agreed,
using rosejoint in that manner is a sin.
Would never pas scrutineering at FS.
What vehicle is it from ?
Otherwise...
You can readily get the 'maxi' ball joint dimensions.
(maxi balljoint -> used in most locosts)
So if you have acces to a lathe...
FERRARIST
posted on 28/8/14 at 05:27 AM Reply With Quote
There few reason why using such solution is preferable for me.
First is that sourcing right parts and services to make locost in my country is a little nightmare, i'm living in the 5th largest city here and believe me or not nearest pipe bender that can bend 50x4mm seamless pipe is 70km away from here.
Second is that because of the first reason i prefer to use parts from cars that i know very well and if i mess a part i just scrap it and take another........
I know about maxi joint is used a lot but my upright hole is bigger than it and it's for a joint cone working in a opposite direction.
Car will be used for trackday only with our laws here is't impossible to make it road legal. i'm using mostly Alfa Romeo 156-166 parts for the reason above.
Read a lot of good or bad opinions about maxi joints here and in US locost forums, and that's why i'm in doubt which joint will be strong enough to work in pull-out application like this.
Hope you understand.
phelpsa
posted on 28/8/14 at 07:53 AM Reply With Quote
Originally posted by drt
agreed,
Otherwise...
It would pass scrutineering at FS, as many cars this year, last year and the many years before have done. There is nothing inherently wrong with the arrangement if it achieves the design goals set out.
My preference would be to use a ball joint from something that was designed to be loaded in that direction however (ie not from McPhereson Strut).
[Edited on 28-8-14 by phelpsa]
motorcycle_mayhem
posted on 28/8/14 at 08:02 AM Reply With Quote
Sylva were quite happy to use a rose joint, as you picture, in single shear, at the bottom of their modified Escort strut. I've seen this on their Riot device. They were also quite happy to use a Fiesta front upright, modified, inverted, at the rear.
Just do it and see what happens?
mark chandler
posted on 28/8/14 at 08:15 AM Reply With Quote
If your shock absorber landed on the hub I do not see any issue, as it is landing on the lower bone this will be taking the whole cars weight.
If you do this make sure you have a big washers incase it fails.
Regards Mark
pewe
posted on 28/8/14 at 09:18 AM Reply With Quote
IIRC the F27 uses a Ford Transit steering ball-joint.
Seems to do the job and to my mind safer than a rose-joint as less likely to detach from the centre.
Also the steering ball-joint is enclosed and was designed for that type of application.
Cheers, Pewe10
bbwales
posted on 28/8/14 at 09:51 AM Reply With Quote
Having had a Rosejoint shear on my rear wishbone as I was going down a French motorway I steer well clear of using them on wishbones, 3 Pirouettes and the rear end hitting the central crash barriers tend to do that.
posted on 28/8/14 at 02:56 PM Reply With Quote
Surely a spherical bearing pressed into the lower wishbone is a better solution. A more fail safe solution considering the loading on the bearing itself in it's weakest plane. It also removes the shear loading on the rod end shank.
prawnabie
posted on 28/8/14 at 04:00 PM Reply With Quote
I always thought your quick release mech on the steering whel failed? Must be old age!
Def old age - I think I mixed you up with Bizzle!
[Edited on 28/8/14 by prawnabie]
bbwales
posted on 28/8/14 at 04:20 PM Reply With Quote
Yep a case of mistaken identity, definitely a rose joint in my case.
FERRARIST
posted on 28/8/14 at 05:54 PM Reply With Quote
Thanks for your opinions people, i'll stick with modified kind of front lower wishbones that i used on my mid-engined Alfa 156......brutal and ugly solution, but i use balljoint that originally fits into this upright, and on later stage when project completed i may try better solution......
Just completed chassis frame, both upper wishbones, bought alloy rad, set of wilwood pedals and 4 GAZ dampers, and i'm eager to complete it in few months......
Is 85kg good achievement for chassis frame weight??????
Sam_68
posted on 28/8/14 at 06:38 PM Reply With Quote
It's pretty unexceptional, for a 'Seven'-type spaceframe. Depending on your drivetrain, you're still on target for your 660kg all-up weight, though: the last 'Seven' design I worked on had a chassis about 16 kilos lighter than that, and an all-up weight (with Ford Duratec engine) of about 575kg.
drt
posted on 28/8/14 at 07:48 PM Reply With Quote
I invite you to read 'pat's corner'
http://www.formulastudent.de/fsg/pr/news/details/article/pats-seven-deadly-sins-of-fs-design/
Fs cars with that setup have always been excluded in the design competition.
It is inherently wrong. And even if you are self confident and fem up the saft, stating it will hold.
The ball will always come out the socket sooner or later...
But the silver model on this vehicle might do the trick
agreed,
Otherwise...
FERRARIST
posted on 28/8/14 at 08:34 PM Reply With Quote
Well it's my newby build, and second overall in my country - owner of the first disintegrate spectaculary in pieces on some time-attack event.......that's why for my first build i prefer more weight and safety........
Well it's a nice read, months ago while browsing for info i found same link, and here is why i asking for more experience....
[Edited on 28/8/14 by FERRARIST]
Sam_68
posted on 28/8/14 at 09:07 PM Reply With Quote
Yes, I apologise. My wording came across as overly critical, I think.
85kg is certainly not grossly overweight, either.
drt
posted on 29/8/14 at 12:13 AM Reply With Quote
Hi there again
The alfa 156,166 did have a mcpherson/double guiding arms hybrid front suspension right ?
Do you see it possible to use the OEM lower balljoint ?.
http://www.alfaworkshop.co.uk/alfa_lower_156_wishbone.shtml
Here you can get the balljoint seperately;
LANCIA Y10 (156) 1.1 PETROL BALL JOINT SS124 5743
FERRARIST
posted on 29/8/14 at 06:20 AM Reply With Quote
Hi there again
Well it may sound insane for all of you, but i used same OEM balljoint cutted and rewelded to tubular wishbones on my 156's.....when you look at below pictures you maybe ask how ball joint handles welding heat - there is a way to "recycle" same ball joint, as i said i may sound insane for you, but it's common practice here.
And this wishbone survive 2 years on a 1250kg car with front V6 engine, survive 2 more years after i moved engine on rear end of the car.......and i'm running 2506418 michelin full slicks.......as you may see from the clip......
http://youtu.be/D2ON21ZAFaU?list=UUKdh-yZtLNdHCN5FL25tNOw
Than's why i can use same ball joint, but i need to search for alternatives......
[Edited on 29/8/14 by FERRARIST]
phelpsa
posted on 29/8/14 at 05:10 PM Reply With Quote
There is a difference between Pat and other design judges marking you down in the design competition and it failing scrutineering. I attended three competitions in three countries this year and at each one there were cars running with that arrangement. None of them did well but none of them had a dramatic suspension failure either.
There ball will not 'always come out' as long as you adhere to the maximum axial load of the bearing.
[Edited on 29-8-14 by phelpsa]
coyoteboy
posted on 29/8/14 at 05:34 PM Reply With Quote
It's still bad design if the correct method is available to be used. Just because you CAN ride an elephant to work in the morning, doesn't mean it's going to like it, not potentially going to kill you at some point and purely from some principle - just wrong. I've seen quite a few REIB failures at the few FS events I've been to, even on bulky ones. The reason they are marked harshly is because it's a design event and it's a bad design.
The other problem you have there is the fastener will be in single shear - another bad idea, but we're not entering an FS competition so it's your call.
[Edited on 29/8/14 by coyoteboy]
Sam_68
posted on 29/8/14 at 05:55 PM Reply With Quote
It's possibly worth picking up on this comment, in that since Sylva use top rocking arm suspension, the bottom arm is very lightly loaded in comparison: it's not reacting the weight of the car via the coilover, when you hit a bump. It's just acting as a track control arm (loading the Rose joint axially, in the 'correct' direction) and taking a share of the fore-aft loads from braking, in a direction which, while it's trying to bend the shank of the Rose joint, isn't trying to push the ball out.
It's perfectly fine in the Sylva application; it's very questionable in the OP's application.
Ball joint would be correct. Spherical bearing in a machined housing on the wishbone (inserted from the correct direction to make it 'failsafe' by the machined housing retaining the ball if it presses out, and secured in place by a circlip) would be second choice. Rose joint as suggested would be a last resort, even if correctly sized.
drt
posted on 31/8/14 at 02:30 AM Reply With Quote
SAM68 has the answer
As you wat to recycle most of your current racing car I understand?
And you have a much 'stronger' top balljoint... (still not ideal)
(isn't that a transit drag link btw ?)
-> put the spring on the top arm.
Maybe a cantilever like on a fury (among others)
(maybe strengthen threaded shaft)
Or... just think outside the box...
Use a real old fashioned King pin.
Like on this Cooper f3 car
So drilling out your upright and use a shaft sat in nylon or... as bush.
Don't take me up on this, as I know that it is bad in so many ways.
FERRARIST
posted on 31/8/14 at 10:52 AM Reply With Quote
No, it's Land Rover Discovery rod end.....
P/N QFS000010 QFS100060
