Author: Subject: How long did your IVA test take
killerferret666
posted on 31/8/14 at 05:24 PM Reply With Quote
Simple question really, just wondering how long it can take, I know this can be dependant on problems. Retests are obviously shorter
Building DDR GT4
Miami Gt4 Blog - Click Here
serieslandy
posted on 31/8/14 at 06:28 PM Reply With Quote
I got there for 8 and left about 12.30.
A hell of a lot longer than I thought.
killerferret666
posted on 31/8/14 at 06:31 PM Reply With Quote
Reason I was asking is because im trying to determine should I make a lunch.
I get cranky if I don't eat
Building DDR GT4
adithorp
posted on 31/8/14 at 06:38 PM Reply With Quote
My SVA took all morning. That should have been it... Then they tried for an extra hourafter lunch, to have another go at getting it through the emissions (they had spare time before the next appointment turned up). I still failed but it wasn't for lack of effort on their behalf.
http://jpsc.org.uk/forum/
serieslandy
I would take something to eat, even if you take it home again. Also take a couple of drinks. My tester made me a tea but some are not so nice.
MsD
posted on 31/8/14 at 06:55 PM Reply With Quote
Got there at 1, left at half 3. It all depends how well the tester knows the manual and how many times their equipment gives up the ghost!
Mark.
b3ngy
posted on 31/8/14 at 08:13 PM Reply With Quote
mine was 8am 'til about 1.30. Had a couple of tea breaks and lunch break in there as well.
The Black Flash
posted on 31/8/14 at 09:14 PM Reply With Quote
8:15 'till just before 12. They even made me a brew
killerferret666
posted on 1/9/14 at 07:40 PM Reply With Quote
I can add arrived at 8am - finished at about 2.30 / 3pm ....was a long day for me!
Building DDR GT4
The Black Flash
posted on 1/9/14 at 09:36 PM Reply With Quote
Sounds like they really went to town on it...that's a looooong test.
neilp1
posted on 2/9/14 at 06:46 PM Reply With Quote
Mine was an hour
alexmitton
posted on 24/9/14 at 09:23 PM Reply With Quote
was about 3 hours but had a few snags (12 in all).
Failed the speed test so he went through everything and we made a list so when i came back it would be quick and easy.
mark b
posted on 24/9/14 at 09:42 PM Reply With Quote
Speed test what does this consist of then?
serieslandy
posted on 24/9/14 at 09:52 PM Reply With Quote
They put the car on a set of rollers and run it up to speed.
They check that the speedo reads slightly under at 30, 40, 50, 60 and 70mph but not over. Then it is adjusted if possible to be within a set tolerance. I think mine took 3 attempts and was set to 68mph @70mph. It should be easy if you have a digital dash.
alexmitton
posted on 24/9/14 at 10:41 PM Reply With Quote
Actual speed vs speedometer.
I was out by miles !!!
It was the 1st test he did but we did everything else and he pointed out a few things just to tidy up.
The guy was spot on.
mark b
posted on 25/9/14 at 05:23 AM Reply With Quote
Mmmmm mine is on a cable where/how do the digital ones pic up the speed?
adithorp
posted on 25/9/14 at 09:52 AM Reply With Quote
Digital speedo's either have an electrinic speedo sensor in the box (where the cable usually goes) or more commonly on kits, take a signal from a hall-effect sensor mounted in the tunnel, picking up pulses from magnets on the prop.
If your speedo is cable type, are you using the donor engine, 'box, diff and wheel/tyre diameter? If so you should be OK.
mark b
posted on 25/9/14 at 12:43 PM Reply With Quote
Yes I'm on my donor box and diff wheels are 15" so not a million miles away from standard so fingers crossed!
