Author: Subject: Red top facet, malpassi filter, swirl pot
The Knobs
posted on 16/9/14 at 08:50 PM Reply With Quote
Need a red top facet pump, fuel swirl pot, small 1L with 8mm push on fittings ideally, malpassi filter with pressure gauge, 8mm, also roll over valve/non return valve. If you are upgrading from carbs to FI then you may have all these bits kicking about. Cheap as possible would be good email tim.price@axionel.co.uk for quickest contact
[Edited on 16/9/14 by The Knobs]
The Knobs
posted on 7/10/14 at 08:51 PM Reply With Quote
still need theses bits
