Author: Subject: Cleaning Coked up Head/valves
davidimurray
posted on 29/9/14 at 07:31 PM Reply With Quote
As per the question any tips on the best way to clean up a coked up head - combustion chambers and valves particularly.
[Edited on 29/9/14 by davidimurray]
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
ian locostzx9rc2
posted on 29/9/14 at 08:01 PM Reply With Quote
Wire brush on a drill works ok
Nickp
posted on 29/9/14 at 08:10 PM Reply With Quote
Spin the valves up in a drill (pillar is best, or hand drill in vice) and use varying grades of sandpaper (start coarse, finish fine). Just make sure to avoid the valve seats and stems
posted on 29/9/14 at 08:48 PM Reply With Quote
Get it chemically cleaned, comes up like new for not much money.
posted on 30/9/14 at 08:00 PM Reply With Quote
gasket stripper on the head and a bench grinder with a wire brush for the valves
threadbare wallet
posted on 30/9/14 at 08:44 PM Reply With Quote
Stick it in the dish washer a few times you be amazed!!!
Very few things are "really" needed.
baz-R
posted on 2/10/14 at 01:42 PM Reply With Quote
anything thats a sodium hydroxide based cleaner shoud shift it off
oven cleaner is cheap and easy to get hold of or gasket remover is another option
