James
posted on 4/10/14 at 12:35 AM |
Monarch Midi Water Softener
Heya,
Anyone got a water softener?
Been recommended the Monarch Midi water softener by both the plumber who put in my boiler and my boss who's fairly technical.
http://www.monarchwater.co.uk/products/ultimate-midi/
Any thoughts or recommendations with it? Before I spend 500 quid!
I was going to go with the 22mm hi-flow version.
Thanks,
James
[Edited on 4/10/14 by James]
- Muhammad Ali
TheGiantTribble
posted on 4/10/14 at 01:29 PM |
I've got a Monarch.
I was selling a few through work, and all my customers and their customers seemed happy with them, so it was an easy choice for me.
It was easy to fit, and fitted into the space I had.
splitrivet
posted on 4/10/14 at 07:52 PM |
Seems a lot of dosh James just to get softer water.
Bob
James
posted on 5/10/14 at 09:09 PM |
Bob
You're right mate! Plus on-going cost of salt and 'leccy.
Blame my Mrs and her 'sensitive' skin!
Also, to be fair it's pretty bad round here (yeah, yeah, everyone I know says they live in the area with the hardest water! ) but it's
bad enough I have to chip it out of the kettle every few months and it takes hours to clean the shower/taps etc.
I've got a mate at somewhere that sells them so I'll see what price I can get it for and go from there.
Anyone else?
Thanks,
James
- Muhammad Ali
Grimsdale
posted on 6/10/14 at 12:52 PM |
copper piping requires the presence of limescale in the water to prevent corrosion. If you must use one, i'd take a blend of softened water and
tap water. Normal 'soft' tap water still typically has 50mg/l of limescale which gives little issue but protects the pipework. Very hard
water can get up to 200mg/l.
I would not recommend the installation of any new copper pipework without allowing normal water to flow through it for a period of months to build up
a protective layer.
Softened water must never be used to fill a central heating system for the same reason.
I've seen copper pipe reduced to the thickness of tracing paper when a water softener has been used, so i'm often worried by their use!
splitrivet
posted on 8/10/14 at 10:19 PM |
a protective layer.
Isnt that the reason they have to braze pipework in France Andy because of the soft water.
Bob
