Author: Subject: Duratec Head Lubrication
davidimurray
posted on 25/10/14 at 04:53 PM Reply With Quote
This might be a stupid question, but how does the oil in a Duratec lubricate the cam lobes, bucket followers, valve stems etc? Looking at the head there is one pressure feed in, that runs into a passage down either side of the head. The camshaft bearings are then cross-drilled into this passage. Apart from those I can't see any other holes/jets for lubrication. Does the oil simply flood out of the camshaft bearings and then get flung around to lubricate everything?
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
Paul Turner
posted on 25/10/14 at 05:03 PM Reply With Quote
There will be feeds to lubricate the bearings and feeds to lubricate the followers. The lobes will get plenty of splash.
davidimurray
posted on 25/10/14 at 06:48 PM Reply With Quote
I can't see any feeds to the followers as there is nothing in the guides.had the head completely stripped hence why I am curious!
