Author: Subject: Rear light mounting
wandr
posted on 25/10/14 at 09:27 PM Reply With Quote
Rear light mounting
Has any one out there any suggestions for mounting rear fog and reverse lights in the upright position. Is there a plinth or something you can get from a supplier? I have made some but they look a bit horrible so I want to change them or cover them with something. Any suggestions welcome
big-vee-twin
posted on 25/10/14 at 09:58 PM Reply With Quote
Here's mine, its the rectangle one in the middle mounted on a plinth\housing, bought from bolt on bits.
[img] rear view
rear view
[/img]
[Edited on 25/10/14 by big-vee-twin]
http://www.triangleltd.com
renetom
posted on 26/10/14 at 05:04 PM Reply With Quote
Hi
Its only the fog light that has to have an angled plinth
so that the beam is horizontal, the reversing light does not matter.
several car bit suppliers sell them, as mentioned bolt on bits
car builders solutions etc
Good luck
René
rear panels
rear panels
[Edited on 26/10/14 by renetom]
Smoking Frog
posted on 26/10/14 at 08:19 PM Reply With Quote
The brown underground plastic pipe can be used, if they are the same size as these. Waste of time if you have to buy the pipe however.
They are about twice the weight as the plastic ones that can be bought.
